I have a 1111196 distributor which I know is for a 327/350 motor. I also think it is for a 1967 motor. What I don't understand is what I thought was a date code of 3 H 30 or 9-30-63. Is that not a date code or am I reading it wrong? Thanks
Ken,
H= August for Distributors according to Corvette by the numbers.
The 9 is confusing, I would guess year, but the 1111196 is a 1967 distributor.
It's probably a service distributor that was manufactured in 1973 and sold through a GM dealer parts department.
RON
Ok that would account for the date but why use the 67 numbers. Why not use what was available in 73? I know they are just removable tags or are you saying the tag was some kind of service tag rather than original when it was serviced? That the distributor is a 67 and re-manufactured in 73? Very confusing.
Distributors were manufactured with many different configurations. Different advance weights/springs, different main shafts, vacuum advances, etc.
I would expect your distributor to have the 1967 part number, because the 1973-produced distributor was produced in accordance with all the configuration parameters consistent with the 1111196 unit.
In other words, it wasn't simply a "Corvette" distributor, but one made for that application.
