distributor wiring
I got the car two years ago and had the problem since day one. Even put on a new edelbrock 1406 carb ,, no help.
I have the old point dist. and coil so thought I would put it bake in and try again
I do not know where the wires go or from with the old dist. sitting on the bench with one black wire coming out the bottom.
What wires go the coil??? I know if I turn the engine over with the old dist in and want to go back to the MSD.I will have to be sure the rotor points at plug 1 with the cap removed and the timing marks at O degrees. Thank Chuck weather in Wis is 50 degrees and no salt on the doars after 10" two weeks ago.....
A 12-ga. pink wire comes through the grommet in the firewall from the ignition switch and connects to the bottom terminal on the ballast resistor, and another 12-ga. pink wire from the engine harness connects to the top terminal on the resistor (the other end of that wire is at the + coil terminal).
The other pink wire (18 ga.) at the coil (+) terminal is also in the engine harness, and comes from the small "R" terminal on the starter solenoid; it feeds a full 12 volts to the coil when cranking. If the harness is original, both pink wires are crimped to one spade connector at the coil connection.
If the car has a radio, there's also a capacitor attached to the coil bracket - its black lead also connects to the coil (+) terminal.
Do you have a MSD system???? not to sure if it is a good idea or not??
