DZAuto
Thank you guys for sharing the memories and providing those wonderful pictures.
My Dad who is 83, lives next door in an apartment over my barn and who drives his '56 around told me this story:
It was WWII in Burma, he was a motor pool sergeant and one day while looking through an American destroyed vehicle impound for badly needed parts, looked up to see a zero and a P-38 in a fight. He had been told the P-38 was an incredibly strong platform but was not any where near as manueverable as the zero. Dad figured the P-38 was a goner but the pilot climbed out like a rocket with the Zero on his tail then dove straight down towards the ground. At the last minute the guy in the P-38 pulled up and the zero trying to duplicate the manuever ripped his wings off and crashed to the ground. My Dad was 18 years old at the time and it shook him up.
His stories are priceless and it takes a couple glasses of wine to coax them out but when these guys are gone there will be a bit of history gone forever.
Merry Christmas
Ralph
Pratt & Whitney R-4360 Wasp Major
http://www.eagle.ca/~harry/aircraft/fury/reno.htm
"Frank Sanders had obtained the fairly complete airframe of Burmese Air Force T Mk.20 VZ368 (serialed UB-451 in Burmese service) and had the aircraft stored in its wooden shipping crate at the family's Chino, California, hangar during 1979. The two-seater was an ideal candidate for Sanders' project, so the Centaurus engine was removed, the airframe thoroughly cleaned and stripped, and a search begun for missing components while Sanders began tackling the engineering needed for the conversion. There was no doubt that the big Sea Fury could handle the R-4360, but problems such as a new cowling, motor mount, propeller, and new internal systems all had to be solved. By the end of its development life, the R-4360 was developing well over 4,000 horsepower, and in the early 1980s complete engines were available, along with a strong parts supply. With the help of sons Dennis and Brian and wife Ruth, work on the new racing aircraft began to proceed rapidly. Sanders also subcontracted some of the work to the vast aviation talent pool at Chino.
Sanders put lots of detail work into his new racer, some of which is not readily visible at first glance. For example, the rather clunky two-seat canopy arrangement was subtly refined to produce a unit that created much less drag than the normal canopies. As usual, the British air-brake system was dispensed with in favor of much more efficient American equipment, including brakes from an F-102. The completed aircraft made its first flight from Chino on 6 August 1983, and few problems were encountered. However, it soon became apparent that a larger vertical stabilizer and rudder were needed to handle the increased power and larger propeller, so the vertical surfaces were suitably enlarged. The two-seat, dual-control configuration was retained (unique for an all-out Unlimited, but Sanders wanted the aircraft to be useful as a possible high-speed test bed). Dreadnought created a sensation when it arrived on the ramp at Reno 1983. Finished in a sparkling Royal Air Force scheme of silver and red, Dreadnought was one of 32 Unlimited aircraft set to qualify that year. In the cockpit was General Dynamics executive Neil Anderson, an ex-Marine Corps fighter pilot and test pilot for the F-l 6. However, Anderson was regarded as a rookie because he had never raced in an Unlimited event. Anderson took Dreadnought out on the 9.187-mile course and hit 446.39 miles per hour, making him the fastest qualifier. Anderson did not hold back in Sunday's Cold race and went on to win at 425.24 miles per hour. Over the years, Dreadnought has been a regular Unlimited participant and has enjoyed its share of success, but the big Sea Fury has been partially eclipsed by Rare Bear and the new generation of highly modified Mustangs. At Reno 1995, Dennis Sanders qualified the racer at 434.667 miles per hour, which put the plane in fifth place (giving some idea how Unlimited speeds had increased since Dreadnought's first Reno outing). Immediately after winning the Gold heat race on 14 September (at 426.122 miles per hour), Sanders declared a Mayday and safely put the racer down on the runway-after years of faithful performance, the big R-4360 had finally come apart, and Dreadnought was on the ground for the rest of Reno 1995."
I am lucky to live in a location where a DC3 flys near my house at least twice a day (to enjoy the raspy radial sound).
The Bristol Centaurus used in the Hawker Sea Fury was the ultimate development of the sleeve-valve engine - here's a shot of the gear train in the accessory case that drove the sleeves. How'd you like to set all THOSE gears "dot-to-dot".
Nothin' to it man, just "connect the dots"!!!!
If I change 1 spark plug per minute and take 2 ten minute breaks...
336 minutes + 20 minutes = 356 minutes..
"Hey... I'll see ya'll in 6 hours.. gotta change the plugs."
My pipe smoking Engineer cousin Jim Thurman designed the landing gear for the B-36...
He said the General that layed out the B-36's specifications originally wanted the gear to be
capable of landing in a field dotted with 3 foot high tree stumps.... but Jim and his cohorts
talked him out of that idea...
In the mid-80's I was employed as a control systems engineer and helped with fire alarm system testing on the Hughes Flying Boat (“Spruce Goose”) when it was displayed in Long Beach, CA. The FLS system had smoke detector heads and horn/strobes in the wings (important for a wood plane).
The Flying Boat used eight Pratt & Whitney R-4360 engines, and the learning experience while servicing the alarm system was that each wing had a catwalk system and vestibules so that each engine could be serviced in-flight. No need to land for engine service, just freewheel the prop and change the plugs (all 56 of them).
The docents (guys who worked for Hughes and on R-4360 engines who volunteered to help maintain the aircraft) commented that the engine rooms on the Flying Boat were unusually clean. The P&W corncob engines were prone to leaking oil, and the Flying Boats limited service was not enough to soil the plane. I do not know if the B36 had the same in-flight engine service capability, but clean up at altitude would have been interesting (and I imagine OSHA would have condemned the procedure).
Roy
While attending Oskosh a few years ago I remarked to Ellsworth Getchell that I was glad to see that he had kept the Centaurus engine when it seemed that most others had gone to the Wright R-3350. He said that he had one extra set of replacement sleeves and when they were gone be forced to do the same.
Questions: Do the have a shorter life than "standard" valves?
Do you have any pictures that show the valve area? Your picture of "clockwork" is something I could never have imagined. It simply blew me away!
Thanks, Tom
if it pulled up next to the Corvette?
With all the radical choppers and H-D engine builders it's a shame none have teamed up with an experimental aircraft enthusiast and machined a block and master rod configuration for a H-D radial aircraft engine (?maybe they have?).
Merry Christmas!
