Return fuel line
Old Dec 21, 2006 | 10:20 PM
midnight1957's Avatar
midnight1957
Default Return fuel line
I am installing a LS1 in my 62 and have to run a return line. Where would be the best place to bring it out from the tank going through the body, maybe near where the original line comes out.
Also where would be the best place to weld it into the tank so that it does not interfer with any of the parts that fit over the tank, BTW the tank is new and never had any gas in it.
I will be using an outside frame mounted electric pump.
Does anyone know if the LS1 will fit in the same place as the 327, I have side nounts welded on the frame because I have a Fatman rack and pinion frontend?
Thanks for all of your help, you guys have never let me down,
Wade
Old Dec 21, 2006 | 10:22 PM
midnight1957
Default 4l60E transmission
Also I an installing a 4l60E transmission and does anyone know it the rear trans mount will be in the same place as the original 4 speed?
Thanks,
Wade
Old Dec 22, 2006 | 07:30 AM
vettes1st's Avatar
vettes1st
St. Jude Donor '06
I ran my return line into the sender unit. It runs along the frame with the supply line. The LS1 should fit like a glove. I have a 6-speed so I can't comment on the trans mount.
Old Dec 22, 2006 | 07:33 AM
Venari's Avatar
Venari
If the side mounts are placed for a SBC you'll need some offset mounts, try some of the engine swap sites (I'm thinking of early Camaro.) Look up Chevy High Performance for engine swaps, you'll soon find what you're looking for.
Old Dec 22, 2006 | 11:49 AM
Russ T Gate's Avatar
Russ T Gate
I also run a external pump. I used steel braided lines and AN fittings. I ran the lines along the frame and attached them with insulated clamps. For the return line I drilled a hole in the filler neck and ran a piece of stainless tubeing to the bottom of the tank and pointed the discharge away from the fuel pickup. I did not weld in a fuel sump, I placed the pump lower than the tank and have been running this way for 4 years with no problems.
Good luck
Russ
Old Dec 22, 2006 | 12:36 PM
cbernhardt's Avatar
cbernhardt
C1 of Year Finalist (track prepared) 2019
What are using as the outlet from the tank to the pump?
On my '62 Ram Jet engine car I have an external inline pump mounted on the inside of the passenger side frame rail. I used a stock tank and tapped into the drain plug for the outlet to the pump and used the normal outlet line for the return. This works fine until you have about 3 gallons of fuel in the tank at which point any hard turn will occasionally cause momentary fuel starvation. If you do not have a sump I would strongly recommend adding one.
Charles
Old Dec 23, 2006 | 01:23 PM
Russ T Gate
Charles
I don't know who your reply is directed at?, but if it's to me I will agree with you that a sump would work well with FI cars, however in my case the system I have now meets my every expectation. I used the stock fuel outlet port and mounted my pump on the frame right next to the tank I then ran #8 line to a 10 micron filter mounted on the firewall then to the fuel rail, the return line is #6 and runs along the drivers side of the frame to the filler neck. I have autocrossed and run out of fuel with this setup and I have not experienced any negatives that I'm aware of. Plus I can still run my spare tire tub (I don't) I don't know if you can if you sump your tank.
Russ
Old Dec 23, 2006 | 04:21 PM
cbernhardt's Avatar
cbernhardt
Russ:
Actually my question was directed to Midnight1957. From his post I assumed he is using the original outlet pipe as a feed to his pump. On the 62 you can add a sump onto the bottom of the tank and not interfere with the spare although it will require a little fiberglass trimming.
Charles
To Return fuel line
