pushrod clearence issues
Old Dec 24, 2006 | 12:48 PM
panchop's Avatar
panchop
Default pushrod clearence issues
well I went to adjust the valves on the new 327 engine i built and #3 and 6 intake pushrods need more clerance thru the 292 head. i checked it and did it before it got to this stage. i don't see what changed. anyhow. anyone know some trick , you don't have to take it all apart again , way to open up the pushrod passages a little bit. I think i'm not going to bother with it till next week. enough already.
merry christmas
Greg
Old Dec 24, 2006 | 01:11 PM
Kensmith's Avatar
Kensmith
Is the push rod seated in the center of the lifter? Double check as this would be an easy fix.
Old Dec 24, 2006 | 01:16 PM
MikeM's Avatar
MikeM
merry christmas
Greg
Are your rocker arms the new kind that self center on the valve?
Old Dec 24, 2006 | 01:45 PM
panchop's Avatar
panchop
I'm using 1.6 probe shaft rockers.
Old Dec 24, 2006 | 02:13 PM
Injected Stingray's Avatar
Injected Stingray
Theres only one way to do it right You have to take the head off and make clearance with a die grinder or take it to a machine shop if you need more than .060". You run the risk of breaking through so be careful. Good luck Chris
Old Dec 24, 2006 | 02:32 PM
knight37128's Avatar
knight37128
With the shaft rockers you will need to open them up a bit.
You could get a big magnet. Put the magnet below where you are grinding to catch the metal.
The possibility of small metal in the oil pan is a scary thought.
Old Dec 24, 2006 | 02:38 PM
panchop's Avatar
panchop
sigh, off they come again. ordered one of those comp cam tools for slotting the head with a drill bit. Oh goody, another learning experiance. LOL
Old Dec 24, 2006 | 03:22 PM
AZDoug's Avatar
AZDoug
C1 of Year Finalist (performance mods) 2019
2017 C1 of Year Finalist
Duct tape and shop rags.
if the block isn't all oily, it will stick fine and catch everything.
Doug
Old Dec 24, 2006 | 05:51 PM
panchop's Avatar
panchop
so what does this all mean.
one of the pushrods.
the 3 and 6 cylinder where the ones that where rubbing, whats this mean.
i also found the inside to be kinda grimey. think I'm going to pull it all the way down and do it again.
Old Dec 24, 2006 | 07:10 PM
AZDoug's Avatar
AZDoug
This is the engine you ran for 20 minutes?
I assume you are referring to the brown stuff on the pistons, i figure those are 3 and 6, correct?
Doug
Old Dec 24, 2006 | 09:00 PM
panchop's Avatar
panchop
yep. i thinking something wasn't working right in those cylinders..
Old Dec 25, 2006 | 12:22 AM
AZDoug's Avatar
AZDoug
Well, heck, dude,
making some logical assumptions, i don't see any need to tear the whole motor apart.
Pushrod 3 and 6 were rubbing, cylinder 3 and 6 have unburned crap on the pistons.
Free up pushrods 3 and 6 and problem will most likely be solved.
Doug
Old Dec 25, 2006 | 12:59 AM
knight37128
Did you get new or are they bronze valve guides?
Old Dec 25, 2006 | 01:01 AM
oldschoolvette's Avatar
oldschoolvette
I would try to do it assembled first with rags and duct Tape. Good luck
Old Dec 25, 2006 | 11:53 AM
Injected Stingray
Originally Posted by AZDoug
Well, heck, dude,
Doug
Valves are hanging open, just clearance the heads. BTW I would open them( all )while you have it apart.
Old Dec 25, 2006 | 12:54 PM
panchop's Avatar
panchop
I ordered the special tool from summit. Cleaned out the valley real good, checked the cylinder walls etc.everything seems cool. Guess I'll just wait for the tool drill ALL the intake pushrod holes and reassemble with newe intake and head gaskets. . All good fun.
Merry Christmas.
Greg
To pushrod clearence issues
