Can someone that has removed the headlight buckets tell me how the pivot ***** on the headlight bucket are attached to the shaft and how I might remove them without damaging them?
I have the bucket out and on the bench. I have removed the set screw in the adjustment collar, the ***** themselves are in pretty good shape but they are not slipping off (assuming that is how they are to come off).
There is an allen head screw on the outboard collar piece. MIne were so covered in dust, rust, and dirt that i couldnt even see the allen head screws and I had to consult this forum just to figure out how the collars were attached. The ball assemblies were also stuck on my headlight shafts and i had to actually clasp the ***** in my vise and then yank on the headlight assemblies to get them to slide off. Good luck!
Do the ***** rotate freely? If not they are frozen and most likely junk. The ***** have a brass sleve that should slide freely on the steel shaft that is attached to the headlight bucket. If the ***** are frozen, try to free them by soaking in penetrating oil, if that does not work, they are junk. If junk, put them into a vice lock them in and start twisting. They ***** are pretty cheap, in the long run it has been my experience that they are better to replace than to use ones that have been frozen.
I reused mine after blasting and coating with grease. I hope they are ok, but perhaps i should replace them before i put the car completely back together.
I soaked the pivot shafts for a few days with Blaster. I kept turning them over to soak from the top and the bottom. Be careful and use a rubber mallet as mentioned above. The shafts are cast and it is easy to snap them if using a heavy hammer. If all else fails, saw the pivots off with a sharp hacksaw and saw very carefully through the bushing without cutting into the shaft. Jerry
