ISI replacement clock
Old Jan 2, 2007 | 06:02 PM
65 DENCO's Avatar
65 DENCO
Default ISI replacement clock
Has anyone used ISI electronic clock kit?
I did the conversion, though I must say the plastic housing they use it not the best. The mounting pins that you slip through the rubber grommets to attach it to your original back plate are a bit short. One of them anyway is about .020 too short and you cant get the clip on it!!! I had to omit the little copper flashed cups and grind away some of the rubber grommet just to barley get the clips on. I wonder why they don't drill the injection mold a few thousands deeper, there is plenty of room on the back side. Very simple fix but most parts manufactures just don't seem to care. What a nightmare- typical parts/raw materials........
Old Jan 3, 2007 | 02:51 AM
JOliver's Avatar
JOliver
I agree!
One thing is alway omit the copper cups don't need them at all and they do more harm than good.I don't know why they still instruct you to put them back in.
