tach
Old Jan 4, 2007 | 07:50 PM
justatoy's Avatar
justatoy
Default tach
tach doesnt work when i connected cable noise comes from tach has anybody rebuilt them sounds like a gear is no good inside tach and how hard to remove does the whole dash have to come out ?
thanks Bobby
Old Jan 4, 2007 | 08:04 PM
RDaddi's Avatar
RDaddi
Default Tach
Probably the gear, possible cable, most likely not the tach, I would remove the dash as a last resort. Look online at Corvette America and they show how the gear fits and you can figure if you want to go the rebuild route. I changed mine to a new GM type with the coil in the cap tach drive from Hot Rods USA.
Old Jan 4, 2007 | 08:06 PM
RDaddi's Avatar
RDaddi
Default Tach
I should have said the gear in the distrubitor.
Old Jan 5, 2007 | 05:07 PM
JohnZ's Avatar
JohnZ
If the noise is coming from inside the tach, it has to come out for a rebuild, and you'll need to pull the cluster to remove the tach (it's mounted on the same plate with the speedo). Forum member Jason Oliver (vetteinstruments@aol.com) can handle the rebuild for you.
Old Jan 5, 2007 | 07:11 PM
bweaver999's Avatar
bweaver999
Could just be the cable needs replace or lubed. Might want to unhook from distributor and put the end in a 3/8" drill. Believe the drill needs to be in reverse for the tach to come up correctly. Quick test though to where the noise is coming from. If noise still occurs, could disconnect from tach to verify it's the cable or tach.
Old Jan 6, 2007 | 03:03 PM
justatoy's Avatar
justatoy
ok when i connect on distributor then i hear noise at the tach and does not work
To tach
