please help
Old Jan 7, 2007 | 06:13 PM
justatoy's Avatar
justatoy
Default please help
took out the car today and got stuck damm just put the new wheels and tires on look good on flat bed heres what happened when i went to start the car is was dead no pwer to fuse box had power going in no head light no radio no dash. i took connector apart clean and check i gave up after two hrs is there a fuseable link any where has anyone had this problem HELP DRIVING ME NUTS
BOBBY
Old Jan 7, 2007 | 06:16 PM
wombvette's Avatar
wombvette
Fix the big red wire in the corner of the firewall connector, and this problem will go away.
Old Jan 7, 2007 | 06:32 PM
justatoy's Avatar
justatoy
what wire when it goes threw the fire wall it doesnt go rt into the fuse box it loops around some where have you had this problem any special place to look thanks
Old Jan 7, 2007 | 06:37 PM
Hitch's Avatar
Hitch
Wayne is talking about instead of allowing the connection to be made via the pins to make a direct connection. The power is youR direct feed and it routinely fails to make a good connection so more than one midyear I'm sure has had this modification. I would make sure that this is your problem though before I would start making modifications.
Old Jan 7, 2007 | 06:45 PM
justatoy's Avatar
justatoy
i get power red lead going in fire wall 12 volts nothing at fuse box all thern look good i clean all removed connector is there a weak link some where that fails on this year
Old Jan 7, 2007 | 07:07 PM
DansYellow66's Avatar
DansYellow66
Wow - my head hurts trying to read this without punctuation. They are suggesting you bypass the bulkhead connector by splicing the wiring and running around it. I think you can first check this out on a trial basis by running a wire from the ignition switch to the positive terminal of the coil and see if it starts. Not sure how difficult it would be to connect it to the ignition switch terminal temporarily, however.
Old Jan 7, 2007 | 07:40 PM
ctjackster's Avatar
ctjackster
Bobby - not sur eif someone answered it, but there is no fusable link in a 65 wiring harness, so that's one thing that is not causing it.
I feel your pain brother, electrical gremlins really stink and mystify all of us from time to time - they require a methodical, work your way backwards kind of approach.
Old Jan 7, 2007 | 08:14 PM
justatoy's Avatar
justatoy
tell me about it (lol) WHAT IS THAT LITTLE BLOCK UNDER DASH i think red lead went to it about half an inch square its on the left up where you knee would be, can that be the problem ?
Old Jan 7, 2007 | 08:16 PM
62Jeff's Avatar
62Jeff
If it is a block with 2 red wires going to it, that is a relay for the headlight motors. Don't think that can cause your problem.
Old Jan 7, 2007 | 08:30 PM
justatoy's Avatar
justatoy
yes i think it had two red wires . damm not going to have a good night sleep tonight. is this a common problem ?
Old Jan 7, 2007 | 08:37 PM
wombvette's Avatar
wombvette
The original wireing would go through the connector and into the fuse box. If you remove the fuse box screws, you can pry the box open. Find the red lead inside and splice that through the firewall to the red wire in the harness on the other side. I actually remove the guts of the connector and run the wire through there. I leave enough wire to plug the connector back up and tape the extra onto the harness. You cant tell it has been done. But it cures the condition that I call " AIR CAR ITIS" permanently.
Old Jan 8, 2007 | 01:31 PM
justatoy's Avatar
justatoy
wanted to say thanks, for everyones help ,i fixed it now i can sleep
Old Jan 8, 2007 | 02:14 PM
ctjackster's Avatar
ctjackster
ok, now so that WE can sleep, how did you fix it? What cured the problem, so we can surmise the cause?
Old Jan 8, 2007 | 02:43 PM
justatoy's Avatar
justatoy
jack i took apart the fuse box clean all connectors in the rear of the box found a broken wire (red) repaired also found a bad green wire on the connector repaired that. after i did that i got 12 volts into the fuse box. the wire looked good by eye broken inside. just want to say THANKS AGAIN what a great group of guys in here . wish i lived closer
Old Jan 8, 2007 | 05:02 PM
bweaver999's Avatar
bweaver999
Sounds like it's time to consider replacing the harness.
Old Jan 8, 2007 | 05:11 PM
70vert's Avatar
70vert
Banned Scam/Spammer
thatreallydoesgivemeaheadachetriingtorea diguessitsavestivesoiwillstopusingmyspac ebartoo
To please help
