Knock offs - adding locking pin
Old Jan 12, 2007 | 10:38 AM
richbopp's Avatar
richbopp
From: Park City to SoCal - according to the map it's all down hill. No bad days in Indian Wells, California
Default Knock offs - adding locking pin
Can you add the locking pins to knock offs?
Drill them and add a pin or just make sure you whack the bejesus out of the spinner with the mallet?
Old Jan 12, 2007 | 10:41 AM
knight37128's Avatar
knight37128
Get a bigger hammer.
Old Jan 12, 2007 | 11:31 AM
capevettes's Avatar
capevettes
CF Community Team
Active Streak: 90 Days
2016 C2 of Year
2015 C3 of Year Finalist
I have had a set of the early repro knockoffs on my 65 since the early 80's. They do not have the pins and they do not move if you put them on correctly. 8 spins and a few good blows with a real lead hammer and your good to go. I put little crayon marks on the outer rim, lined up with the 3 spinner points. This allows me to check at a glance if they have moved. It also saves your hammer from needless damage. They have never moved.
Old Jan 12, 2007 | 11:50 AM
kenEDMUNDS's Avatar
kenEDMUNDS
Do you apply anti-seize to the adapter threads?
Old Jan 12, 2007 | 11:54 AM
JohnZ's Avatar
JohnZ
Adding the pins requires precise machining of slots through the threads on both the adapter and spinner; not worth the effort. Just get a "Mother-Thumper" lead hammer and beat hell out of them, use a little anti-seize on the threads and conical mating surface, mark them for a visual check, and drive on.
http://www.performanceunlimited.com/...ls/hammer.html
Old Jan 12, 2007 | 11:56 AM
richbopp's Avatar
richbopp
Thank you, thank you, thank you.
I think I have a nice deal on a set of knock-offs from a forum member.
Old Jan 12, 2007 | 07:55 PM
capevettes's Avatar
capevettes
CF Community Team
2016 C2 of Year
Yes I do. I didn't know about the "Mother Thumper" though. That's a hell of a weapon
Old Jan 13, 2007 | 05:19 AM
vettefred's Avatar
vettefred
Skip Shift
You could always wire them like the Cobra guys do....
Old Jan 13, 2007 | 01:40 PM
JohnZ's Avatar
JohnZ
I safety-wired the Halibrands on my Grand Sport (from the end of the ear at 2 o'clock to the hole in the wheel at 3 o'clock) with a little slack for visual checks, drove hell out of it, never had one loosen.
To Knock offs - adding locking pin
