Block Casting #
Jan 16, 2007 | 12:57 PM
Block Casting #
Can anyone give me specifics on a block castings # of 3782870? Thanks
Jan 16, 2007 | 01:05 PM
if you mean use in a Corvette, 62-65 Corvette, SB.
Jan 16, 2007 | 01:27 PM
3782870....327...62-67...2
http://www.mortec.com/castnum.htm
Small journal, 4 inch bore. What more do you need?
Jan 16, 2007 | 01:45 PM
Thanks for the info and the mortec website!
Jan 16, 2007 | 05:26 PM
I have one more question. I'm trying to research these #'s on the heads and the block. They are the same. I think it is the engine assembly date? #57058??
Jan 16, 2007 | 06:34 PM
You will find the assembly date "stamped" on the pad.
The cast date of the block and heads will be in the form of "letter" A-L (month: Jan-Dec) 1-31 (day of the month), single digit year (2-7). At least on this block. Something like A 10 6 (Jan 10, 1966) as an example.
Other may have two digit year.
Jan 16, 2007 | 06:39 PM
Quote:
Originally Posted by
knight37128
the 870 block....according to the Black Book was not used after 65...?
Mortec is broader in its assesments on and in it uses of blocks
jack
Jan 16, 2007 | 06:45 PM
66jack
Mortec is broader in its assessments on and in it uses of blocks
jack
There are other cars besides a corvette.
Jan 16, 2007 | 06:47 PM
66jack
jack
yes, I am with you, see my post above; but to be completely accurate, it was used in other GM cars after 65
Jan 16, 2007 | 07:02 PM
knight37128
Oh there are there...
those are
words....
I didn't read all the posts...my fault
jack
