vacuum advance question
I have just put the distributor back into my car ( a different one than what I ran prior ) and noticed while I was setting the timing that when I connected the vacuum line back on to the advance dashpot my rpms jumped considerably....from 850 to about 1700 !!! It is the correct # 236 advance
seems to run better with out the line connected...any help from the experts ?
Its a 375 hp fuelie
Its a 375 hp fuelie
Mkae sure the diaphragm in the vac can isn't blown and giving you big vacuum leak, vac leaks are real good at raising RPM's.
Doug
Doug
Received 1,859 Likes
Its a 375 hp fuelie
Its a 375 hp fuelie
St. Jude Donor '07
here's what i suggest, in this order:
1. get it to idle at the lowest practical rpm, 850 would be great.... (with the vacuum advance disconnected and plugged)
2. check/set distributor dwell
3. set the timing to the factory spec, with the vacuum advance disconnected and plugged.
4. reconnected vacuum hose to can
5. use a vacuum gauge to adjust the idle mixture screw on the air meter to the highest vacuum reading (connect the gauge to the vacuum advance hose using a 'tee' if you like)
6. adjust the idle using the LARGE idle air screw, do not touch the idle mixture screw
Bill
Bill
