Rear Wheel Alignment
Old Feb 3, 2007 | 12:27 AM
jtranger's Avatar
jtranger
Default Rear Wheel Alignment
I noticed the other day, at the car cruise, that the rear tires on my '65 slant inward at the top of the tire toward the body/wheel well. It is noticeably different from the front tires which appear to be straight in alignment. Is this normal or are the rear wheels in need of alignment? It has the stock skinny tires. Thanks
Old Feb 3, 2007 | 01:37 AM
wombvette's Avatar
wombvette
Should be about 1/2 degree negative camber.
Old Feb 3, 2007 | 03:50 AM
67435animal's Avatar
67435animal
You need to align the wheels. It probably has not been done in a long time so I'd suggest that you take it to a professional. It's pretty easy to adjust camber only.
To Rear Wheel Alignment
