door lock question
Old Feb 4, 2007 | 01:11 PM
1Redctoo's Avatar
1Redctoo
Default door lock question
I tried to post this but it went out as a reply to Mattyg92's interior door lock question . So Im trying again .
Anyway , my door locks wont unlock with the key and I'm thinking they were swapped left to right when the car was painted . I've got the door panels removed and now is the time to fix the problem . So, which was does the tap on the cylinder face ? Currently they both face toward the rear of the car . My thought is if they were reversed during painting then maybe the linkage is mis aligned just enough that the cylinder tab doesnt quite move far enough to unlock the door ???? The key will lock the doors but just wont unlock them .
My ride :
Old Feb 4, 2007 | 04:08 PM
gcb1966's Avatar
gcb1966
they point forward, that way they will interlock with the metal retainer that slides on from inside the door.
Let me know if u need a pic as i just got done taking my whole lock mechanism apart.
Old Feb 4, 2007 | 04:10 PM
Sierrabarry's Avatar
Sierrabarry
I had the same problem until I used the ignition key instead of the glove box key. Problem solved.
Old Feb 5, 2007 | 02:30 AM
1Redctoo's Avatar
1Redctoo
GCB1966 - If you have some pics I would love em !
Old Feb 5, 2007 | 10:22 AM
66since71's Avatar
66since71
Similar problem with mine. I flushed them with WD-40, and they worked fine. Mine must have been just an accumulation of crud (like you might get in a body shop?). May be of some help?
Old Feb 6, 2007 | 12:54 AM
1Redctoo's Avatar
1Redctoo
Default locks
Mine are both facing toward the rear . The key works fine going in and turning to lock the door but it turns to unlock the door and wont move the actuator rod enough to unlock it . I'll try and swap them out so the tap points forward and see what happens . I looked at a parts catalog today and it showed the tab facing forward . Ill give it a try and see what happens . Thanks for the input .
Old Feb 6, 2007 | 11:40 AM
gonefishn's Avatar
gonefishn
St. Jude Donor '09
1Redctoo, here is a picture of the lock assembly for the right hand door (acutally a 66 roadster too). The original lock assembly was in exactly this same position as shown pointing forward.
John
Old Feb 7, 2007 | 10:01 AM
gcb1966's Avatar
gcb1966
RedCtoo - Looks like John beat me posting a pic. Hope that works for ya. i'm going to close my doors up this weekend, let me know if u need any other pics.
Chuck
Old Feb 10, 2007 | 01:32 PM
1Redctoo's Avatar
1Redctoo
Default door locks, still a problem
Gonefishn - thanks for the pic , I'm finally getting around to putting things back together . Your pic helped me figure something else out . I found the backing support plates for the door handles lying at the bottom of my doors ! didn't know where they went till I saw your picture .
Now I have the tab facing forward but still now luck , seems like the linkage is binding up now . Do you have a picture that shows the lower section of the linkage ?
gcb1966 - Thanks also , any more pics would be appreciated
Old Feb 10, 2007 | 01:44 PM
1Redctoo's Avatar
1Redctoo
Default locks cont .
Another question , this is awful simple but , when you stick your key in the lock are the teeth on the key facing up or down ? I'm getting the feeling Bubba mixed up all the parts so I don't know what goes with what .
After I get these locks figured out I can put my door panels back on and start to reinstall my radio . I had it rebuilt and it sounded really good in the guys shop . I know its not going to be great but heck all it did before was buzzzzzzzzzzzzzzzzzz .
Old Feb 10, 2007 | 01:58 PM
revupL78's Avatar
revupL78
Not sure if my car is correct (it's been around the block a few times if you know what I mean) anyway the teeth on my door key is down when lock/unlock doors
Old Feb 10, 2007 | 02:02 PM
62Jeff's Avatar
62Jeff
Down on every classic GM car I own from the 50's to 70's, including the 65 vette.
On the 65 Driver's door, I insert the key and turn it to the left to unlock.
On the 65 Passenger's door, I insert the key and turn it to the right to unlock.
1Redctoo's Avatar
1Redctoo
Thats what I was thinking but my memory doesn't quite recall . heck, I don't recall what was for lunch yesterday !
Anyway , I'll probably be running back and forth from here to the garage for awhile trying to figure this thing out if anybody else want to chime in I'll be happy to hear from you .
Old Feb 10, 2007 | 02:24 PM
1Redctoo's Avatar
1Redctoo
Default Locks Work !!!!
Thanks to everyone ! After having the car for 4 years I can finally lock it . It always gave me the ******* to leave it unlocked when we stopped anywhere .
Now on to the radio reinstall
Old Feb 10, 2007 | 10:07 PM
gonefishn's Avatar
gonefishn
St. Jude Donor '09
Sorry, I do not have any pictures of the lower section.
One thing I'd like to point out if your not all done. The metal reinforcement plate has black pliable materila behind it. Believe this it to allow contour to the door curves. The 3M black strip caulk is a good match to the material. Can also be used behind the door panels on areas over select screws as the factory did.
Just wanted to share that since your reinforcements had fallen off and you may not have been aware.
John
Old Feb 11, 2007 | 01:27 AM
bweaver999's Avatar
bweaver999
Why lock a rag top? I never lock mine, figure if someone wants to take her for a ride that bad, they will just poke through the top (if it's ever up) and be gone.
To door lock question
