front spring question
Old Feb 6, 2007 | 09:47 PM
salty_waders's Avatar
salty_waders
Default front spring question
I'm about to re-install the front springs on my car (65 small block) after rebuilding the front end. Do the springs go back with a particular end up or down? In other words, is it possible to put the springs in up-side-down? Thanks
Old Feb 6, 2007 | 11:00 PM
Sky65's Avatar
Sky65
St. Jude Donor '05, '09, '15
If the springs are progressive the tight coils go up. You also want to seat the top of the spring in the pocket. The bottom falls where it may as long as it sits flat in the pocket.
