Leaf spring Problem on 64 Please help
Old Feb 6, 2007 | 11:14 PM
splidecision63's Avatar
splidecision63
Default Leaf spring Problem on 64 Please help
When I had my 64 on the lift, I noticed the back leaf springs were touching the rear wheel. The car rides real low, scrapes over rail road tracks. The real wheels could not turn because they were pined to the leaf springs. Are the springs worn out, or do I need new shock or is something else? The shocks appear to be ok.
Thanks,
Geroge[/QUOTE]
Old Feb 6, 2007 | 11:19 PM
66since71's Avatar
66since71
Camber adjustment will affect the clearance there. So would non-stock wheels with too much back spacing. Should not happen in any case, with stock wheels, even with a worn out spring. If the interference is with the tire, it may be too wide.
Tell us some more about your set up??
Old Feb 6, 2007 | 11:35 PM
knight37128's Avatar
knight37128
Got a tape measure?
Measure the distance from the center out on each side. Post what you come up with and I will measure mine if no one else has that handy.
I will be under mine tomorrow anyway as the weather broke today (got up to 54). Not warm enough to do a lot but I will do what I can (or want to do).
Old Feb 6, 2007 | 11:55 PM
Tintin's Avatar
Tintin
Cartoon Character
Once again, this is right where I was last Friday. I looked on a lift and my tires were being pushed by the spring. You need to look at the springs when the car is on the ground. My tires touch the spring on a lift because in fact this is quite normal due to weird rear suspension geometry. I was also told that if you get air under the rear tires over a bump, this will freeze the wheels as well to some amusement of the passersby. Try puting a couple of trans jacks or blocks under the tires and have another look. I have a 64 as well by the way so I can attest to this being the case. They do not touch on the ground.
If they touch on the ground then your spring has become de-cambered methinks and you will need a new one...
Old Feb 7, 2007 | 09:05 AM
MikeM's Avatar
MikeM
Especially the spring part.
Old Feb 7, 2007 | 01:42 PM
JohnZ's Avatar
JohnZ
What size tires and EXACTLY what kind/size/type of wheels?
Old Feb 7, 2007 | 09:28 PM
splidecision63
Thanks for the input. I'll have pic's and measurement and tire sizes tomorrow.
George
Old Feb 8, 2007 | 08:13 AM
splidecision63
Ok here goes my tires are Firestone Champions 195/75/15'sThe measurement from the inside of the wheels is 47 1/2"
Here are a few pic's
http://i10.tinypic.com/29pu2ky.jpg
IMG]http://i13.tinypic.com/2luxdv7.jpg[/IMG]
Thanks George
Old Feb 8, 2007 | 08:39 AM
splidecision63
Old Feb 8, 2007 | 08:43 AM
splidecision63
Old Feb 8, 2007 | 11:02 AM
66since71's Avatar
66since71
Thanks George
George, If that measurement (47 1/2") is on the ground, from rim to rim (before jacking up the car - to get an accurate static camber), it suggests a back spacing on the wheels of about 5", which would certainly result in what we see in the pictures. Also, the tires look as though they are mounted on wheels much wider than stock. On a drum brake car, the 15x7 passenger car wheel with 4.3" back spacing might do that. Can you take off a wheel and measure it?
Edit: lots of threads on back spacing, check the archives. Stock wheels will have a back spacing around 3.5", depending on the wheel.
Old Feb 8, 2007 | 01:39 PM
splidecision63
Hi .
I gave you sosme bum info. I measured the distance between the wheels while the car was uup on the lift. It is 49 1/2 "
What is back spacing and how do I determine if the wheels are to big?
Thanks George.
We are going to a Baton Rouge Corvette meeting this evening so I might not be able to get back with you until later tonight or tomorrow
Old Feb 8, 2007 | 02:59 PM
66since71's Avatar
66since71
Hi .
Thanks George.
George, Backspacing is the distance from the mounting surface of the wheel to the inner most edge of the rim (not the tire). My guess still is that yours is more than 4", and that is the problem. This link has a fair diagram that may help.
http://www.minilitewheels.com/measuring.htm
We'll look for your note tomorrow..
Edit: take a look at this thread too. Sounds like others have had exactly your problem.
http://forums.corvetteforum.com/show....php?t=1607214
Harry
Old Feb 8, 2007 | 11:28 PM
splidecision63
Thanks for the info. I think I understand, I'll measure tomorrow. How can I tell waht rims I ahve?
Thanks Geroge
Old Feb 9, 2007 | 10:05 AM
66since71's Avatar
66since71
Thanks Geroge
I am not near my parts book for another week or so, so I cannot give you the info on what the stock rims should measure. They should be either 15x5 or 5.5 and have a backspacing of about 3.5. (you might find it in the archives)
When you measure, there is an extra 1" of width to accomodate rolling the beads on the wheel. So a 5.5" wheel will measure (between outer rim edges) 6.5". If it is not close to these dimensions, it is one of the hundreds of different wheels made that would bolt up to you car.
Let us know how it comes out!
Harry
Old Feb 9, 2007 | 06:31 PM
splidecision63
Default leaf spring problem
Hello Harry,
Thanks for staying with me. Here are some picc's I took today. Is this helpful? I am not sure what I am looking for, but I think it's the measuremet on the rim I took. It show almost 5 inches.
Geroge
Old Feb 9, 2007 | 07:57 PM
knight37128
That is a big tire for a mid-year.
To Leaf spring Problem on 64 Please help
Old Feb 9, 2007 | 09:24 PM
66since71's Avatar
66since71
Hello Harry,
Geroge
George, Looks like all of the measurements are taken from the surface the tire is resting on. (better would have been the inside edge of the rim.. but this is probably enough to figure this out.)
Looks like section width of the tire is around 7.75" and that the wheel offset (not backspace) is around 3/4". If it is a 7" rim (I think it is based on the pictures), then the backspacing of the rim (not the rim-tire assembly) is about 4.75". Definitely a problem.
We could nail this down a little better if you could confirm the measurement from the rim edge to the mounting surface.
In any case, I think at least part of the problem is that you have the wrong wheels on the car.
PM me if you want to take this off line. HOWEVER... there is no problem doing it here, especially since we could get some help from some of the other guys (JohnZ?) who are up on this stuff.
Harry
Old Feb 10, 2007 | 11:53 AM
magicv8's Avatar
magicv8
The 195x75r15 tires are correct replacements for 7.75x15 originals - no problem there. Your wheels appear to be originals. Stand one up with a piece of wood across the back of the wheel - not touching the tire. If the wood is on the flat edge of the rim that retains the tire sidewall (not the turned out steel rim edge) the distance to the mounting surface on the back of the rim face (the surface that contacts the brake drum) should be less than 3.5 inches.
When your car is in the air with the wheels hanging, do the yokes pop out of the diff farther than 1/8 inch??
Are your strut rod bushings intact? The pics appear to show pieces of rubber hanging out of the strut rod bushings. If the bushings are shot, you will have the problem that you see on the lift, and a car than steers itself from the rear when the road is irregular.
Old Feb 11, 2007 | 08:40 PM
splidecision63
Thanks,
Geroge
[/QUOTE]
Crazy idea. I have 6 1/2 " long bolts on the end of each leaf spring, I'll shorten them the 5" and see what happends
If this doesn't work. I'll start changing wheels.
Thanks all you guys for you help. I have not fix the problem YET but I learned a lot.
George form La. that's louisiana
