block numbers
Old Feb 7, 2007 | 06:18 PM
drewdog66vette's Avatar
drewdog66vette
Default block numbers
searched the forums, but need to check on this block. id T06I0HC, any help is appreciated.
Old Feb 7, 2007 | 07:13 PM
Donald #31176's Avatar
Donald #31176
Need the casting # and date. Look at the bellhousing flange.
Old Feb 7, 2007 | 08:02 PM
ctjackster's Avatar
ctjackster
as above - what you posted is the engine assembly date and suffix code from the stamp pad, which might be numbers that appear on the block, but not the "block number" that will help us zero in on what the block was used in. Best we can say is that it is a Tonawanda block assembled on June 10, year uncertain. And HC is not a C2 engine suffix, smarter fellows will tell us what GM cars did use an HC suffix.
Post the block casting number, and for extra credit, the cast date.
Old Feb 7, 2007 | 08:13 PM
knight37128's Avatar
knight37128
If it is a small block, it is a 327 275hp from 1965 or a 350 250hp from 1969.
Anything else?
Old Feb 7, 2007 | 08:49 PM
ctjackster's Avatar
ctjackster
usage?
Old Feb 7, 2007 | 08:54 PM
stingrayl76's Avatar
stingrayl76
Originally Posted by ctjackster
usage?
HC 1965 327 Powerglide 275HP 4V full size
HC 1969 350 m/t 250HP 2V A, F, X bodies
Old Feb 7, 2007 | 09:05 PM
knight37128
usage?
Are you planning on using this block?
It is from Tonawanda.
Old Feb 8, 2007 | 09:20 PM
AColbe01's Avatar
AColbe01
He's implying, NOT a Corvette engine, as I was told, " Don't feel bad many times the guys would stick in another engine to keep their car going" For what it's worth MINE has a Tonawanda engine also. Someone went spent extra effort to keep it looking close to original till I had to replace the old AFB carb for egged out throttle shaft holes and had to put the dual-snorkle in the garage storage room.
Mine is a "driver." Looking at other options for a little more SOTP performance.
Enjoy the Ride!
Andy
Old Feb 8, 2007 | 09:24 PM
knight37128
Enjoy the Ride!
Andy
Mine is also from Tonawanda.
Old Feb 9, 2007 | 11:56 AM
drewdog66vette
Default many thanks
sorry to be so vague, but my buddy has this block in a chevy bellaire and was sure it was a vette engine. those are the numbers he gave me. he thought 66 but i now see it is prob from a 65 as stated. many thanks. he was offering to pull it if i wanted it for mine. but i got other things to spend my money on. the bellaire he is selling in houston. thanks again and sorry for the lack of info.
Old Feb 9, 2007 | 01:12 PM
JohnZ's Avatar
JohnZ
It could be from a '65 passenger car, but not from a Corvette; no Tonawanda-built small-blocks were used in Corvettes.
To block numbers
