Headlight switch removal
Old Feb 10, 2007 | 02:02 PM
ren's Avatar
ren
Default Headlight switch removal
Even though it's way too cold to finish my wiring project today, I figured that I'd get the gauge cluster positioned so that it would be ready to go. As usual, I encountered a problem. The car is a 63, gauge cluster is 65. Several months ago, I realized that the new wiring harness(63) would not hook up properly to the gauge cluster's headlight connection. I ordered a 63 headlight switch. It plugs in to the new harness perfectly. My problem is how can I remove the old one from the back of the gauge cluster? The actual switch is gone, what's left is the flat bracket that holds the switch housing. I'm afraid to force it. With my luck, I'll break the back of the gauge cluster. Any suggestions would be greatly appreciated. It's supposed to hit 30 tomorrow. Maybe I'll try to finish it.
Old Feb 10, 2007 | 02:07 PM
62Jeff's Avatar
62Jeff
Did you remove the big chrome round nut on the front of the instrument housing? That nut holds the switch assembly to the housing, on my 62, 65, and even my 56 Olds. I would assume it would be the same on your car.
Old Feb 10, 2007 | 02:12 PM
ren's Avatar
ren
Is that what the pull knop fit's through ?If so, I didn't take it off yet. I'lltry right now.
Old Feb 10, 2007 | 02:15 PM
62Jeff's Avatar
62Jeff
Doh! I'm sorry, you said HEADLIGHT switch, not IGNITION SWITCH.
Ok, you need to remove that small slotted nut in the center of that trim ring, sorry for the confusion.
Old Feb 10, 2007 | 02:22 PM
ren's Avatar
ren
Thanks for your help 62Jeff. That appears to be the problem. Couldn't get it on the first try. I think that i need a screw driver with a bigger head. I'll try later. Thanks again.
Old Feb 10, 2007 | 02:24 PM
62Jeff's Avatar
62Jeff
If you are very careful (I do it this way) you can use a pair of needle nose pliers. Open up the pliers so that one of the 2 ends of the "nose" are each in one of the slots, then twist.
Old Feb 10, 2007 | 08:18 PM
ren's Avatar
ren
Pliers worked great. Thanks for your help.
Old Feb 10, 2007 | 08:29 PM
62Jeff's Avatar
62Jeff
Old Feb 10, 2007 | 09:46 PM
gonefishn's Avatar
gonefishn
St. Jude Donor '09
Gotta love this forum. Look at the time stamps. Wow 62Jeff!
To Headlight switch removal
