Fuel filter question
Old Feb 23, 2007 | 09:11 PM
jkuzzy's Avatar
jkuzzy
Default Fuel filter question
My 64 coupe has less than 2500 miles on it since 2001. One of my big projects is to get the old fuel all cleaned out and I am on my 5th or 6th tank of new gas after running high octane, seafoam, etc.
In the process, I have had the carb rebuilt, put in a few plastic see-through fuel filters (to see exactly how bad the line was dirt wise), and replaced all flexible hoses.
Now for the question: Should the fuel filter always be full of gas or would it vary? I ask because I found that the flexible line from the hard line to the fuel pump was sucking air due to somebody else's crappy workmanship. I could understand how that might change the level. The only thing I could change is the fuel pump. I guess I always assumed that the fuel filter was full. I have never had a see thru filter so I never thought much about it.
Thanks for your input.
Old Feb 23, 2007 | 09:14 PM
Procrastination Racing's Avatar
Most I have seen vary, usually like half to 3/4 full. There is usually some air in them for some reason.
Old Feb 23, 2007 | 09:20 PM
jkuzzy's Avatar
jkuzzy
I have seen it all over the place. Tonight it was barely had any gas in it. Upon starting it and revving a few times, it was half full. I forgot to mention that the filter is currently laying on it side with the inlet/outlet horizontal to the ground.
I was even thinking that maybe there was something wrong with the fuel pump and gas was somehow draining into the block due to a diaphragm problem. I do smell gas.
Old Feb 23, 2007 | 09:26 PM
Bluestripe67's Avatar
Bluestripe67
Active Streak: 90 Days
My filter is vertical, and has anywhere from half to very little if it sits for more than a week. It's in the garage right now so I can start is, but maybe tomorrow. If so I'll look at the filter. Dennis
Old Feb 23, 2007 | 10:58 PM
jkuzzy's Avatar
jkuzzy
That would be great. Thanks for the help.
Old Feb 23, 2007 | 11:06 PM
67L36Driver's Avatar
67L36Driver
Unless you mount a filter vertical, they always seem to trap a bubble of air.
To Fuel filter question
