S-10 or Bazer Frame for restoration Comments
I have been reading comments on the SR III frame and Paul Newman frame for restoration. Why not use a less expensive frame? Will a S-10 frame work with the C4 suspensions? If not, any other frames out there?
Thanks George
Thanks George
Probably for the same reason you go to Al Knoch for a top and not Home depot and get a blue tarp. It was designed for it, it works, and its a corvette (translation: gonna cost anyway, so pony up). Ya gotta pay to play is what I have always heard. Besides, who wants to reinvent the wheel?
Sure, any frame will work with enough work. The S-10 frame can't just bolt up the C4 suspension, so there would be a lot of cutting fabrication and welding. If you are going to all this work, why not build an entire new chassis, instead of one from under a pickup truck. By the time you built a jig to weld the suspension points in the correct location under the S-10, you would probably have more in the chassis than you could buy a new SRIII chassis for, and it would still not be near as good.
Take a look at the pic below, and you will see the attention to engineering that goes into one of these frames. This ain't no pckup frame! There are a lot of kit cars these days that use a donor S-10 chassis, but this is a way to build a car cheap, not a way to build a car that will handle like a supercar.
http://img.villagephotos.com/p/2003-...3/P0000974.JPG
Regards, John McGraw
2021 C1 of the Year Finalist - Modified
I have a Jeg's front clip and a Jeg's 4 link rear clip under my 59, connected by 2x3 square tubing. And it's going to be a LOT of work to finish. But it will fit 14 x 32 rear tires when I am done !!
Pops
Pops
