Engine Temp Gauge Low?
Old Mar 5, 2007 | 08:50 AM
runutzzzzz's Avatar
runutzzzzz
Default Engine Temp Gauge Low?
O.k. guys... I'm stumped...
In a 67 the temp gauge is reading low!! I've searched and found if it reads high it possibly is a bad ground at the gauge cluster.
This is what I've done. I've replaced the sender and the gauge.
I've measured the resistance at the sender and it seems to be off.
This is why I say off. I replaced the thermostat and it was a 180. Acording the the chart I got off here it seems to be opening at 140-150
and it never gets hotter than 150-160 after I shut the car off.
Do you guys have any other suggestions?
Thanks!
Old Mar 5, 2007 | 08:53 AM
crw41's Avatar
crw41
1st step in sorting this out is to use an IR guy and shoot the top heater hose when the car is run for a while
that will tell you the true operating temp and you can go from there based on your result
Old Mar 5, 2007 | 08:59 AM
62Jeff's Avatar
62Jeff
My 65 did this exact same thing after installing a "correct, calibrated" temp sender from a reputable vendor.
I installed an old sender I had from my 71 oldsmobile vista cruiser, and now the temp gauge reads 180 - just like my IR gun.
Old Mar 5, 2007 | 09:42 AM
magicv8's Avatar
magicv8
The Wells sender I got at an azone in OK reads 4°-5° higher than the original GM sender that I bagged. Close enough for the low cost. Actually DZVETTE bought it for me on our Power Tour long haul.
Check to make sure the sender is grounded. A lot of people put sealant on the threads - which makes the senders inaccurate.
Old Mar 5, 2007 | 02:09 PM
JohnZ's Avatar
JohnZ
Check for corrosion on the terminals inside the multiple connectors on the engine compartment side of the fuse block; the dark green temp sender wire runs through the inboard connector, and if the terminal connection is corroded, resistance will increase, which will show an abnormally low gauge reading.
Old Mar 5, 2007 | 08:40 PM
runutzzzzz's Avatar
runutzzzzz
O.k. guys... Got an update.
I put back in the "old" sensor it had a larger "tip" than the one I took up.
The OHM readings on are inline with the chart I got.
It reads higher than the one with the skinny "tip" but it's still off!
I measured the resistance on the inside of the car and it's accurate.
I ran a new wire into the car and it didn't change.
Any other ideas?
Old Mar 5, 2007 | 09:30 PM
magicv8's Avatar
magicv8
Have you checked the actual engine temp to make sure the tstat is ok?
Old Mar 6, 2007 | 09:46 AM
runutzzzzz's Avatar
runutzzzzz
No. I'm going to buy a temp gun today.
But the reading on the meter reads the correct temp according to the chart I got off here.
Does anyone know the differance between the two temp. senders that the vendors supply?
Old May 31, 2007 | 09:03 PM
w1ctc's Avatar
w1ctc
Here's what I did. Removed the sensor and suspended it in a beaker so the lower part was under water. Connected the gauge wire and a ground (at a point near where the sensor screws in) to the sensor. Put the beaker on a hot plate and kept close watch on the gauge and the water temp. This tests the whole sysem.
As far as the thermostat. It does not open all the way at the stamped temperature, it just starts to open and is fully open at some higher temperature. Push the thermostat open enough to put a thread or string in the passage. Hang it in a container and when it reaches the opening temp, it will fall off the string to the bottom of said container.
To Engine Temp Gauge Low?
