Just warm your engine to temp. pull the valve cover and check the lash on number 1 cylinder at TDC now let the engine cool. Check the differance now you have your cold lash setting.
Was it JohnZ who put out a paper on how to set the valve last cold for a solid lifter motor?
Either way, please post it if you got it. I've done my hot and it is just a PITA.
The specs for my cam are .018 for exhaust and intake. What should I use cold? .020
The original DUNTOV solid lifter camshaft had adjustment settings of
.008 and .018 intake and exhaust. Warm engine, and then remove valve covers and coil wire. If possible have a friend 'bump' the starter to get # 1 to top dead center
As suggested bring #1 cylinder up to TDC. Either # 1 or #6 will be at center when the timing mark on the dampner is at "0" on the timing marker. Feel both rocker arms to see if both valves are loose. IF both are either #1 or #6 is at TDC.
WITH #1 UP
ADJUST
EXHAUST- 1,3,4,8
INTAKE- 1,2,5,7
ROTATE ENGINE ONE FULL TURN AND BRING # 6 UP TO TDC
WITH # 6 UP
ADJUST
EXHAUST- 2,5,6,7
INTAKE- 3,4,6,8
It will take a little practice to feel the feeler gauge 'pull' between the valve stem and rocker. You will however, discovwer a loose valve will be very sloopy. Tighten the rocker nut until snug and the push rod will not spin, then reverse the nut to loosen until the clearance is snug on the .008 and .018 feeler gauge.
Old Grumpy taught me years ago how to do this. He used to adjust his valves between each race at the drags. Still works today.
I wish I had that same info for an L-71. I'm fixin' to fire mine up for the first time soon.
BL
Bryan:
The method Ironcross described will work fine for you. That's the way I do it. I'ts easier for me to keep track of what I've done and what I haven't. It'll work for the 30-30 too. You just have to be more careful about where the valves are and their relative positions.
WITH #1 UP
ADJUST
EXHAUST- 1,3,4,8
INTAKE- 1,2,5,7
WITH # 6 UP
ADJUST
EXHAUST- 2,5,6,7
INTAKE- 3,4,6,8
Not bad if you have until next Sunday to get ready for the next round that you should be ready for with in a hour.. This will take you all day and into next week to finish a lash job. No racer would ever use this proceedure more that once!
Ironcross,
The way you described is the way I was taught by Jerry "The King" Ruth. Ever heard of him?
You are right about getting ready for next round. On our blown alcohol car, if the guy was spending more than 5 minutes on the valve lash checking / adjustment, we sent him back to tire wiper status.
I never had to adjust valves between rounds even though I was a racer of sorts. That's how many times I did it that way, once! And that was a long time ago. Been doing it the other way, before and since.
Edit: I guess I should add that "the all day, and into next week" method would be very accurate. Especially for somebody that doesn't quite understand the relationship between the valves opening/closing and piston position.
