Hedman Side Exhaust Headers
Old Mar 7, 2007 | 08:28 PM
Dicecal's Avatar
Dicecal
Default Hedman Side Exhaust Headers
Been thinking of going with some headers for my side exhaust setup. These look pretty good, anyone have any experience with them?
Old Mar 7, 2007 | 08:33 PM
65 DENCO's Avatar
65 DENCO
My buddy runs those. 4 inch tubes all the way down the side, turn outs with traps. Sounds good, makes good power. looks cool.
Old Mar 7, 2007 | 09:11 PM
Ol Blue's Avatar
Ol Blue
2024 C3 of the Year Finalist- Unmodified
I put a set of these on 30 years ago. They matched up to the factory sidepipes perfectly.
Ol Blue
Old Mar 8, 2007 | 10:37 AM
Bluestripe67's Avatar
Bluestripe67
Active Streak: 90 Days
I put a set on my SB about 15 years ago, no existing troubles. I did have to put a torque strap on the motor since the driver side collector flange was super close to the frame. Dennis
Old Mar 8, 2007 | 10:40 AM
MasterDave's Avatar
MasterDave
Moderator
Got 'em on my sbc, just had to make a small elbow to hook to the side pipes. No problems.
Old Mar 8, 2007 | 11:09 AM
silverslashstreak's Avatar
silverslashstreak
I have been running them for years, good fit and good clearence issues.
Old Mar 8, 2007 | 12:09 PM
JohnZ's Avatar
JohnZ
I used them (Hedman #68280) when I built my Grand Sport ten years ago, into 4" sidepipes.
Old Mar 8, 2007 | 12:12 PM
Dicecal's Avatar
Dicecal
Thanks for the info! Looks like a winner...
Old Mar 8, 2007 | 12:48 PM
rickm63's Avatar
rickm63
Default Any pictures of the side pipes
I would like to replace my hookers because the are rusting at the collector,and are big bucks to replace.
Old Mar 9, 2007 | 10:03 PM
rickm63's Avatar
rickm63
Default hellow any body home
any pics.?
Old Mar 9, 2007 | 10:21 PM
Mikey65's Avatar
Mikey65
Hook a brother up that's on a gov computer.. I can't see anything
Old Mar 9, 2007 | 10:33 PM
nassau66427's Avatar
nassau66427
From: going faster miles an hour...with the radio on in browns mills new jersey
You could always send them to Jet-Hot and have them coated as a cost effective means of having them look better.
Old Mar 10, 2007 | 01:24 PM
Russ T Gate's Avatar
Russ T Gate
I've had hedmans on my car for 20 yrs with no problems, however the 13/4" primaries are a little small for the 502. I'm using them now but wish they made a set with 17/8" or 2" with the proper flange to work better with the heads on the 502. I do recommend that you do have them coated. Mine were done by JetHot and have held up well.
Good luck
Russ
Old Mar 11, 2007 | 02:49 PM
sting1's Avatar
sting1
Russ,
Am putting 502 in my 66. Does the factory side pipes bolt right up to the headmans or is there other mods that must be done? What has to be done to the mounting flange to make them work properly? Any advice would be appreciated as I have not purchased them yet.
Thanks in advance,
Sting1
Old Mar 12, 2007 | 11:18 AM
Russ T Gate
Sting 1, you need a reducer from the collector to your side pipe. Jegs or Summit sell these. You will need a 3" to the size of your side pipe. Cut your side pipe and weld in the reducer so it bolts up to the collector. Fire up your engine and go and have some fun
Russ
ps. You may need to grind the header flange to create clearance for a few head bolts at the rear of the head. You'll see what I mean when you try to bolt the header to the head. No big deal, just a small modification.
Old Mar 13, 2007 | 11:45 PM
vettegozzzz's Avatar
vettegozzzz
Sting,
Do you already have your 502? I'm shopping for the best price on a ZZ502 for my 65 coupe. Have you seen threads or information on a 502 install?
I'm subscribing to this thread because I also have factory side exhaust and want to keep the look.
To Hedman Side Exhaust Headers
