fuel pump differences
Old Mar 11, 2007 | 10:26 AM
Sundevil64's Avatar
Sundevil64
Default fuel pump differences
I have a 64 that has a 70 (based upon number of block and distributor) 350 (4 bolt main) instead of the 327. I replaced the bad fuel pump (mechanical) with a 327 fuel pump not knowing any different at the time. I got the car running and the fuel pump is moving all over the place! Are the arms in the fuel pump different? or are the push rods different lengths in a 350 than a 327? I know pressure and volume can be different from pump to pump, but does that mean the arm is different (the arm that goes into the block)?
Thank you.
Old Mar 11, 2007 | 10:37 AM
JohnZ's Avatar
JohnZ
All small-block fuel pumps are functionally interchangeable, and use the same pushrod and mounting hardware. What do you mean about "it's moving all over the place"?
There's a mounting plate that bolts to the block with two bolts at the bottom, and the fuel pump then mounts on that plate with two bolts that go through holes in the plate into the block.
Old Mar 11, 2007 | 10:42 AM
Ironcross's Avatar
Ironcross
ALL S/B pumps are the same. They do look like B/B pumps but wont work, it brakes the arm. You may now have a bent F/P push rod. Check the numbers off the pump at any good auto parts store. Some may get miss-placed in the wrong box from employees and customer handling.
Old Mar 11, 2007 | 10:56 AM
Sundevil64's Avatar
Sundevil64
Default fuel pump
Sorry about that. I should be more specific. The pump body appears to flex and move while running. I first noticed this when the in line fuel filter was moving around. I grabbed the hard line and noticed that it was moving also. I looked down at the fuel pump and it appeared to be moving in a pulsating manner as if it were flexing each time the push rod would come down to actuate the fuel pump. At first glance I thought the fuel pump was loose, but there is not any leaking oil, and I am sure that I tightened it. I will double check that later today. Has anyone heard of this? I thought maybe the arm length was different or the rod length was different. It is an A/C Delco pump. I was under the impresssion that just about any sbc fuel pump would work.
Old Mar 11, 2007 | 11:01 AM
knight37128's Avatar
knight37128
Did you push the rod into the block when you put the fuel pump on?
Sounds like you have the arm on top of the push rod.
Old Mar 11, 2007 | 11:05 AM
67L36Driver's Avatar
67L36Driver
The pump housing may be cracked and flexing because of it. We had one on our '59 wagon come apart while driving along rt. 3 in southern Ill.
Old Mar 11, 2007 | 11:22 AM
MikeM's Avatar
MikeM
If your pump housing isn't cracked like described above, check to make sure your bolts are clamping the pump tight to the block. Your bolts may be too long and are bottomed in the threaded holes.
Old Mar 11, 2007 | 11:58 AM
Sundevil64's Avatar
Sundevil64
Default fuel pump
Would the pump still work? I "thought" I pushed the rod back into the block. I put a bolt in the front to hold it then once the pump was installed I removed the long bolt.
Old Mar 11, 2007 | 12:56 PM
62Jeff's Avatar
62Jeff
The 2 times I installed the fuel pump on top of the push rod by mistake, simply bent the rod and the car refused to start. I don't imagine you'd have a working pump if it wasn't properly engaging the rod.
I've been proven wrong here for other things before though.
To fuel pump differences
