Hey guys does the radiator core support bolt to the frame horns on each side? It appears so in my assembly manual.
My 59 has a 72 Nova subframe and the frame horns are a good bit wider than on an original C-1 frame, and I do not have a core support yet so I'm sort of spinning my wheels trying to figure this out.
on my 62, which i presume is the same as a 59, the core support bolts to the inner fender panels on the sides and the support is supported on the bottom by the front of the 3rd arm bracket.
Bill
Thanks, Doug
It sounds like a problem, but a solution would be for you to fabricate a mount from the center of your cross member forward to mount your rad support to. The rad support boltds down to the front of the third arm bracket on original frame cars. It sounds like you will need to replicate that mounting point on your sub frame if you are going to use an original rad support.
Here is a link to a picture of an aftermarket frame that has the core support mount welded to the side rails. Keep in mind that this frame does not use the stock C1 suspension.
Charles http://www.carols62.com/59/08230401.jpg
Charles....WOW....not that is a radiator support!!!!!!
The guy who had the car before me did some fabrication work on the front center of the Nova subframe for the core support to mount to (two bolt holes about 4 inches apart). I hope he has the holes placed correctly.
Later today I'm going over to a friends house to look at his 60. He made his core support out of a donor from some other GM car, but used an original support for a pattern....the guy is a wizard at fabrication.
