1963 Carpet Install Question
Old Mar 13, 2007 | 10:38 AM
jbfc2's Avatar
jbfc2
Default 1963 Carpet Install Question
Hi Guys,
Just ordered a new carpet kit from Al Knoch. Whats the best adhesive
to use on the foam backing to put it down?
Thanks,John
Old Mar 13, 2007 | 10:47 AM
65 DENCO's Avatar
65 DENCO
Originally Posted by jbfc2
Hi Guys,
Thanks,John
3m yellow spray adhesive and 3m yellow weatherstrip in the tube for small areas. I did try the clear 3m spray but it soaked up and did not hold well- I think it's for headliners. Just did my carpets with the yellow and it bites hard, so use caution when placeing the pad if it's warm out.
Old Mar 13, 2007 | 11:00 AM
1KULC7's Avatar
1KULC7
Veteran: Coast Guard
I used the spray can of 3m and it worked great. Remember that to do this you do not saturate the floor with glue. The purpose of the glue is to act as a tacking agent not a cement agent, otherwise you will pay hell to remove the carpet once its dry, and more hell to pay when you prep it to put new carpet back on. Again, the spay that Al sells or 3m you can buy at Home Depot works great.
Old Mar 13, 2007 | 09:44 PM
cookie_monster's Avatar
cookie_monster
How many cans of adhesive will it take to do the entire car?
Old Mar 14, 2007 | 09:06 AM
1KULC7's Avatar
1KULC7
ONE...SPREAD IT VERY THIN....
Again consider using the spray cans...two...would due
Old Mar 14, 2007 | 09:10 AM
rponfick's Avatar
rponfick
I think the 3M product is No. 77. I have used it often. It is much better than the other private brands, especially that sold by NAPA.
Just my 2 cents worth.
Ralph.
To 1963 Carpet Install Question
