decode tranny??
Old Mar 16, 2007 | 07:35 PM
Dean757's Avatar
Dean757
Default decode tranny??
gm transmission on left side number is 3884685,rt side 3925660, tailshaft 88b28. Just purchased 63 swc. reverse top far left. Lowest gear is bottom left, next lowest gear BOTTOM right ,highest gear = top right of shift pattern. Suspect 3 speed transmission with 4 speed shifter??? or faulty shifter with 4 speed?
Old Mar 16, 2007 | 08:22 PM
knight37128's Avatar
knight37128
http://www.5speeds.com/muncie2.htm
88b28 : Should be P8B28
P = Muncie
8 = 1968
B = February
28 = 28th (second to last day of the month) [Leap year]
Old Mar 16, 2007 | 09:56 PM
Dean757's Avatar
Dean757
P = Muncie
8 = 1968
B = February
Thanks, any idea if it is a 3 speed or 4 speed with bad shifter/
Old Mar 17, 2007 | 08:10 PM
JohnZ's Avatar
JohnZ
It's a Muncie 4-speed, and either the linkage or the shifter (or both) are screwed up. It SHOULD look like the photo below.
Old Mar 17, 2007 | 10:12 PM
Dean757's Avatar
Dean757
Thanks. It has indy embossed on the side of the shift lever. I plan on purchasing a new shifter before I remove the old one. What brand of shifter do you recommend? Dean
Old Mar 17, 2007 | 10:39 PM
knight37128
Hard to beat the factory shifter.
Old Mar 17, 2007 | 10:42 PM
Don SSDD's Avatar
Don SSDD
Indy is a name on a Hurst shifter, a very good one if not completely shot. Check it out and see if the rods etc are hooked up correctly.
Does it have the 2 bolt mounting for the shifter handle- you can change it to a repro Corvette style. The Indy is a short straight shift handle.
Don
Old Mar 18, 2007 | 09:43 AM
Dean757's Avatar
Dean757
Default muncie 4 speed /shifter problem
Thanks guys. Now I know it is a 1968 muncie 4spd. When it was on the lift for the oil change, the mechanic shimmed the transmission mount due to rubber mount deteriorated allowing linkage to contact frame. He thought that would fix problem. I never paid attention to connections on the shifter arms. I will get it back on a lift and verify. Concern now is : Are all 4 gears good. Or the rods bent/ shifter gates bad. Seems strange that it ended up with functional shift pattern as described. Previous owner info not available.
Old Mar 21, 2007 | 06:39 AM
Dean757's Avatar
Dean757
Default Thanks
Thanks, The shifter was installed incorrectly. It is now working excellent. Trans,Clutch are also excellent
Old Mar 21, 2007 | 01:06 PM
Bill Pilon's Avatar
Bill Pilon
Sounds like some shift arms upside down--Bill
Old Mar 21, 2007 | 03:03 PM
Dean757's Avatar
Dean757
Default Yes Sir
Right on Bill. The arms were upside down. 1 linkage rod broke even though it was heated as we reset everything. Replaced that and it was aok.
To decode tranny??
