need a little engine help
Old Mar 19, 2007 | 10:13 PM
panchop's Avatar
panchop
Default need a little engine help
built a little 327 for my 65 vette. Forged SJ crank, scat I beam rods, 11-1 TRW pistons, probe 1.6 shaft rockers, lunati solid flat tappet cam. 292 heads with 2.05/ 1.6 valves. I degreed everything, checked P/V clearance etc.... Ran the engine about an hour on my test stand. everything fine. I put a couple hundred easy miles on it yesterday. today I dropped the hammer a couple times, shifting at 6800 RPM etc. i pulled of the highway and the idle wasn't right. drove a mile and realized the engine was getting hot. popped the hood and i had thrown the belt. easy fix but now The passenger side pipe has a flat pop, like I have a dead cylinder or something. pulled the plugs and the all look the same. whats my next diagnostic step.
Old Mar 19, 2007 | 10:14 PM
vintagecorvette's Avatar
vintagecorvette
compression test. leak down test.
I am sure others will chime in here.
oWEN
Old Mar 19, 2007 | 10:19 PM
Mikey65's Avatar
Mikey65
Pull the covers and see if you wore any lobes down?
Old Mar 19, 2007 | 10:23 PM
62Jeff's Avatar
62Jeff
Bent a push rod? Broke a rocker?
Old Mar 19, 2007 | 11:02 PM
vettefred's Avatar
vettefred
Skip Shift
Probably floated the valves and bent a pushrod. Check all valvetrain components. Head gasket? I am sure it will be something simple. Fred
Old Mar 19, 2007 | 11:30 PM
panchop's Avatar
panchop
well compression is all the same across the bank. 180 # within a # or 2. I did find that a wire had come off the alternator but i don't see how that would account for the sound. I will pull the valve covers and take a look in the AM. the plug wires look good. Because I have no patience I pulled the valve cover tonight. nothing jumps out at me.
Old Mar 20, 2007 | 09:52 AM
Joel 67's Avatar
Joel 67
header or exhaust manifold leak?
Old Mar 20, 2007 | 10:07 AM
Joys's Avatar
Joys
At the distributor mark all four wires that goes to the right side of the engine with masking tape, pull them out of the dist. cap and gently push them back in their place but not to tight. Start the engine and let it idle, with an insulated pair of pliers or similar gently remove each one of the marked wires and listen for a change in the idle rpm and sound. If one gives no change you have a dead cylinder and can investigate directly to this very cylinder starting with compression(which I believe you have already done) Good luck!
Old Apr 1, 2007 | 05:12 PM
KyleDallas's Avatar
KyleDallas
Shaft rockers aren't forgiving like stud rockers.... Set up/measurement
has to be spot on.... they are awesome when they are right, rev to
your hearts delight..
To need a little engine help
