66 odometer reset mount
Old Mar 20, 2007 | 09:15 PM
66L72's Avatar
66L72
Default 66 odometer reset mount
i cant remember how to remount the trip odometer reset cable bracket
there are 2 large holes in the bottom of the bracket but the spacing is such that no matter where i put it i get interference from the screws that CC supplied me to mount the right fresh air vent cable.
i took it apart but that was 3 years ago.
can anyone help.
thanks
Old Mar 20, 2007 | 09:22 PM
62Jeff's Avatar
62Jeff
The mount bracket is held to the steering column with a U bolt.
Let ms see if I can dig up a picture...
This is from when I began to disassembly my 65 A/C car in order to replace the wiring harnesses. One vent cable (closest to the radio) is already disconnected, the other cable is loosely held in place for reference.
and this is how the steering column mount and odometer mount play together:
Old Mar 20, 2007 | 09:36 PM
66L72's Avatar
66L72
You sir are truly amazing!!!.
now i see that the bracket goes along with the steering column mount and is not attached to the bottom lip of the instrument cluster right side at the lighter.
However on your picture the attachment point for the reset cable is at the back, left side. if it was turned 180 degrees it would put the reset **** at the right side of the column and closer to the frond edge of the instrument cluster.......... ??? seems to be better no?
Old Mar 20, 2007 | 09:53 PM
62Jeff's Avatar
62Jeff
I don't remember the specifics, but I know that I didn't think there was enough room to move the **** to where you suggest, without really pinching the cable "somewhere".
I also can NOT confirm whether or not my car is correct, I simply put it back the way I found it.
Old Mar 20, 2007 | 10:06 PM
66L72's Avatar
66L72
i am 90% sure it goes to the right of the column. i will research further.
thanks for the quick response and the pictures.......
much appreciated.
Old Mar 20, 2007 | 10:51 PM
62Jeff's Avatar
62Jeff
much appreciated.
You are welcome, please post the results of your attempt to move it to the right.
Old Mar 21, 2007 | 01:11 PM
LB66383's Avatar
LB66383
Having just put mine back together not too long ago, I have to agree with 62Jeff. Trying to mount the cable on the right of the steering column causes too severe a bend in the cable for it to ever work smoothly, if at all.
Old Mar 21, 2007 | 02:58 PM
66L72's Avatar
66L72
hi Jeff and LB66
i just found a picture of mine before disassembly, also looked at the owners manual. both show the odometer reset to the right of the steering column........ mystery solved i guess.
thanks again for the help.
Old Mar 21, 2007 | 11:58 PM
66L72's Avatar
66L72
i put it in tonight. not a fun place to work but it went in OK. i am sure that is the correct location. it works fine.
thanks again to all for the input
To 66 odometer reset mount
