Speedometer Cable Length
Old Mar 21, 2007 | 05:49 PM
jtranger's Avatar
jtranger
Default Speedometer Cable Length
Just bought a speedo cable and need to shorten it 1". Can I use a hacksaw or wire cutters to get a clean cut? I don't have any other tools in the garage I can think of to use to cut it. What can be used to cut the cable clean? Thanks
Old Mar 21, 2007 | 06:44 PM
67L36Driver's Avatar
67L36Driver
Cut off wheel in a Dremel tool.
How you gonna get the ends (sleeve/nut) back on?
An inch shouldn't make that much difference.
Now, wait a sec, are we talking about the core or the housing??????
Old Mar 21, 2007 | 10:40 PM
MYBLUEHEAVEN's Avatar
MYBLUEHEAVEN
I went through the same thing, but I just wanted to replace the inner spiral core. Went to a speedo shop and the had the core in bulk. Cut me a piece to the original's exact length and then used a little welding device to finishish the tips correctly. Very inexpensive! Then just had to slip the inner core into the outer tube and everything has worked since.
To Speedometer Cable Length
