Rear end codes
Old Mar 22, 2007 | 09:14 PM
All-Tex's Avatar
All-Tex
Default Rear end codes
I have a 62 and have been cleaning rust off the passanger front side to see the codes. Where are they in the middle or to one side or the other?
Cody
Old Mar 23, 2007 | 02:29 PM
JohnZ's Avatar
JohnZ
The stamps are usually between 7 and 10 o'clock, and are very hard to see - keep cleaning.
Old Mar 23, 2007 | 03:19 PM
DZAUTO's Avatar
DZAUTO
2026 Corvette of the Year Finalist - Modified
2025 c1 of the Year - Modified Winner
2024 C1 of the Year Finalist - Modified
2023 C1 of the Year Finalist - Modified
2015 C1 of the Year Finalist
Cody
All-tex(orwhateveryournameis)idon'tunderstan dwhypeoplewanttobeanonymous,
On the photo of the rear center section below, where the numbers and big P are located, there is a code STAMPED in the same location on the opposite side.
There SHOULD be 2 letters and 2-4 numbers following the the 2 letters.
The 2 letters indicate the the gear ratio (and posi or non-posi). The 2-4 numbers indicate the month and day of the month that the rearend was ASSEMBLED (the cast code on the other side indicates when the molton iron was poured into the mold).
SOMETIMES, the stamped code is EXTREMELY difficult to see (the assmebly worker may have been to hung over from the night before to hit the stamp hard enough), or, there may not even be a stamped code. Nevertheless, that is where the stamped code should be located--------------------if it's even there.
Old Mar 23, 2007 | 09:41 PM
All-Tex's Avatar
All-Tex
I think they missed this one must have been Monday. The casting is 3725899 and the date is F254 but my car is a 62 is this the original rear end?
Cody
Old Mar 23, 2007 | 10:12 PM
knight37128's Avatar
knight37128
Cody
F = June
25 = the day
4 = 1954 or 1964
No not original.
Old Mar 23, 2007 | 10:29 PM
All-Tex's Avatar
All-Tex
It would have to be 54 because 64 was not a straight axle.
Correct?
Cody
Old Mar 23, 2007 | 10:32 PM
knight37128
Correct?
Cody
Corvette had the only independent rear end.
What about passenger cars? Trucks?
Old Mar 23, 2007 | 10:42 PM
All-Tex's Avatar
All-Tex
True True True
Old Mar 24, 2007 | 02:02 PM
JohnZ's Avatar
JohnZ
Correct?
Cody
Nope. It's out of a '64 passenger car - Corvette and passenger car used the same center section.
Old Mar 25, 2007 | 04:17 PM
DZAUTO's Avatar
DZAUTO
It ABSOLUTELY could be an over the counter rear. Chevy continued to manufacture the drop out style center sections AT LEAST up into the mid-late 60s. I've been rebuilding these rears for about 40yrs and just recently, I worked on a rear with a 66 date. Remember, 64 was the last year for this style rear (in pass cars, 62 in Vettes) so for them to still be available from Chevy parts for a few years is realistic.
To Rear end codes
