Electrical problem
Old Mar 24, 2007 | 07:26 PM
Dad's '66's Avatar
Dad's '66
Default Electrical problem
Hey guys, I'm looking for a little help with an electrical problem. Along with the 66 427/425 Corvette that we have I also have a 62 Impala. People in this forum have been so helpful to my brother and I on issues with our Corvette maybe some of you are familiar with the Impala too. I've only had the car for a couple of years. I went out to the garage this morning to move the car and I have no power at all. No lights, no dome light, no radio, not even a click on the starter, nothing. I have had no previous problems before today. I had it out for a ride just two weeks ago. So I checked the battery and it's fully charged. I leave it on a trickle charger with the battery disconnected while it's in the garage for long periods of time. I then checked the battery cable to the starter solenoid and it's got 12.6 volts. I took the starter out and had it checked and it works fine. While I had it out I replaced the solenoid and put it back together and still nothing. I'm guessing it's something under the dash that I may have bumped and has come loose. Does anyone have any ideas? Car show season is right around the corner and I don't want to miss any. Your help would be greatly appreciated. Thanks
Old Mar 24, 2007 | 07:50 PM
plaidside's Avatar
plaidside
Check the bulk head connector. Remove the connector from the engine side and check the connectors. This would be where I would go first.
Old Mar 24, 2007 | 07:55 PM
nassau66427's Avatar
nassau66427
Active Streak: 90 Days
From: going faster miles an hour...with the radio on in browns mills new jersey
Is there another wire in addition to your battery cable coming off the positive terminal of the battery? If so, check that wire for continuity. If that wire goes - you've got nothing. Don't know if your car has that wire but a lot of old Chevys I've had did.
Old Mar 24, 2007 | 09:51 PM
Sky65's Avatar
Sky65
St. Jude Donor '05, '09, '15
Don't forget the ground side! No ground no go as well.
Old Mar 24, 2007 | 09:53 PM
ironarms's Avatar
ironarms
St. Jude Donor '05-'08-'09
fusible link?
Old Mar 24, 2007 | 10:32 PM
Dad's '66's Avatar
Dad's '66
Thanks guys. I'll start looking into your ideas. If you have anymore, let me know. Thanks again
Old Apr 1, 2007 | 07:49 PM
Dad's '66's Avatar
Dad's '66
We have a winner! Thanks Plaidside! That was it. The bulk connector was loose. She runs again! Thanks again to all of you and for all your ideas and help. See ya on the road.
Old Apr 1, 2007 | 08:01 PM
plaidside's Avatar
plaidside
Been there done that!
Old Apr 1, 2007 | 09:41 PM
richbopp's Avatar
richbopp
From: Park City to SoCal - according to the map it's all down hill. No bad days in Indian Wells, California
Me too.....
and once again the Forum is the place to be to get some avice and a possible answer
To Electrical problem
