Script valve covers
Old Mar 28, 2007 | 08:21 PM
theybot's Avatar
theybot
Default Script valve covers
Any one ever buy the after market valve covers threw Corvette central or one of the other vendors? Good quality? Pics? I'm trying to decide if buying a used set and sand blasting them is better than the repos.
Toby
Old Mar 28, 2007 | 08:28 PM
vettes1st's Avatar
vettes1st
St. Jude Donor '06
Looked at Paragon's at Corvette Expo. They looked very nice and are supposed to be from factory molds. Cheaper than old ones too.
Old Mar 28, 2007 | 08:42 PM
tentuna's Avatar
tentuna
I needed one due to the previous owner pulling a buba. Posted a WTB on the forum and found one that way. That might be worth a try, I can't believe a die cast mold that had severe heat checking on the plug and a crack on the female portion is still around.
Old Mar 28, 2007 | 09:11 PM
MarvBarrish's Avatar
MarvBarrish
I bought a chrome set of valve covers from Paragon and didn't care for them. I felt the prep work around the script area, prior to chroming was lacking in detail. I sent them back. I then bought a cheap ugly set of used ones on ebay and bead blasted them, cleaned up all the edges and then sent them off for high temp shiny finish and all is well.
Old Mar 28, 2007 | 09:22 PM
theybot's Avatar
theybot
What do you mean by Hi temp shiny finish? Paint?
Old Mar 29, 2007 | 01:59 AM
AZDoug's Avatar
AZDoug
C1 of Year Finalist (performance mods) 2019
2017 C1 of Year Finalist
I bought a set recently to have polished.
They are from the same mold that made them 40 years ago,a nd that is obvious.
They are not reproduction covers, they are modern production.
Comparing my 40 year old casting flaw covers to the new ones, the mold is really showing its age, lots of new boogers and pimples on the new covers from mold erosion that are not on the old covers.
But, a block sander with 120 grit to remove the boogers and a trip to the polishers and $30 per cover later, they look fantastic with their mirror shine.
Doug
Old Mar 29, 2007 | 11:56 AM
firstgear's Avatar
firstgear
2019 Corvette of the Year Winner
St. Jude Donor '15
Doug
$30 per cover is a very very good price. Will they do more for that amount and if so, can you PM their address and phone number.
thanks, Herb
Old Mar 29, 2007 | 02:46 PM
MarvBarrish
What do you mean by Hi temp shiny finish? Paint? What I used on my valve covers was CermaKrome high temp header coating done by Cap's Brite hot coatings in Fresno, Cal. I've used them for coating many different parts and have been real happy with the results. Regards, Marv
To Script valve covers
