I have a 67 427 with TI ignition. I was told by someone at Lectric Limited that the TI used a ballast resistor. I am sure that he is incorrect. The purpose of the TI ignition was to give full voltage to the coil so it would be able to give a hotter spark. Point distributors needed the lesser voltage so that the pionts would not burn in normal running. The only time they saw full voltage was on the start. Am I correct? If I am not, I want to understand where I went south, Roger Orton
No ballast resistor with TI. If you need a module or wiring, use:
The white wire in the harness is the resistor. It is not a ballast but still there to drop voltage. I think to 9 or 10 volts. The fog of time!!!!!
