windshield installation
Old Apr 5, 2007 | 08:04 PM
64 Roadster's Avatar
64 Roadster
Cruising
Default windshield installation
Hi,
I'm just about to reinstall the windshield on my 64 convertible and i was wondering if i need to lay a bed a sealer compound? If so witch one should i use and shoul i be generous when applying it?
As again thanks for your responses
Old Apr 5, 2007 | 08:43 PM
67-427ci's Avatar
67-427ci
Originally Posted by 64 Roadster
Hi,
You should lay a generous bead of 3M Bedding & Glazing Compound (Part No. 08509) prior to setting the glass & gasket. After it is in, seal between the lip of the gasket and glass with 3M Window-Weld Resealent (Part No. 08633). Then lay another bead of the bedding compound around the base of the gasket and two beads on top of it to seal the trim. There are good instructions in your Chassis Service Manual.
Roy
Old Apr 5, 2007 | 10:04 PM
64 Roadster
Cruising
Thanks for the info. I did a search on this forum and i've read and follow your frame off informations. You certainly did one good job!!
As for the compound, where would it be possible for me to buy some?
Old Apr 5, 2007 | 11:26 PM
67-427ci's Avatar
67-427ci
Thanks for the comment. I purchased my supplies at a local Car Quest parts house.
Roy
To windshield installation
