Engine Tapping
It has developed a distinct intermitant tapping / knocking sound during idle , quite loud I thought it was ends or mains initially but have traced it to the top of the motor , it sounds as if there is something loose in the valve covers or inlet manifold and often the sound goes completely but then returns as if something is being thrown around and then lodging for a few seconds . Increasing revs does not seem to make it worse but it is hard to tell with the increased noise of the motor .
I have lifted the valve covers but found no bits , all the rockers seem tight , no sign of broken valve springs , I also took a quick look inside the dizzy , the weights under the rotor are ok , are there larger weights lower down in the dizzy that could be loose / broken ?
The motor also seems to have a slight misfire again intermitant on idle but it is difficult to tie it to the tapping noise .
Your thoughts would be most welcome before I start stripping down to check cam followers or broken cam lobes etc , I am hoping it may be something simple .
TIA
Mike
TIA
Mike
I'm having a little trouble translating here:
Bitza
Bits
Weights under the rotor
Larger weights down in the dizzy
That aside, I do understand intermittent tapping. I'd say you have a hydraulic valve lifter(s) sticking, worn rocker arms at the valve stem and possibly cut rocker studs. One or all three.
Other possibilities are a sticking fuel pump push rod, broken valve spring and cracked piston skirt.
I'm assuming you have good oil pressure at idle. At least 25 pounds.
I'd look under the valve covers again with the engine running. If it won't tap when you get the cover off, use heel of the hand pressure on the pushrod end of the rocker and see if you get the noise. You can also grasp the end of the rocker and twist it back and forth and see if that sets off the tapping noise.
A rubber heater hose or broom stick from your ear to the engine is also helpful to locate or isolate noises.
If it's a sticky lifter, run some crankcase cleaner through the engine and then drain the oil and refill with the correct type. If you can't find crankcase cleaner, use a quart of Automatic transmission fluid instead.
Mike :- Regarding the questions I must appologise for my UK phrasing , "Bitza" refers to something made up from many parts not all neccasarily originally matching , "Bits" replace with debris ,weights under the rotor refers to the centrifugal set up directly under the rotor in the distributor and "dizzy" just short for distributor .
the little inner spring is making the engine run , but the intermittant noise sounds like the big valve spring to me.That noise you are hearing is the piston hitting the valve.
If it is the spring, change the head gasket and have the valve checked for straightness.
Doug
Mike .
I am working with the block in the car , crank case is off but I have not touched the pistons or crankshaft , do I need access from underneath to remove the cam ?
Cheers
Mike .
I didn't buy the handle but I used an old cam gear and some locking pliers to aid in keeping it parallel.
Good luck
Brian
The cam should slide right out if all the lifters are removed.
Unless you dinged a bearing read bad with a lobe and raised a burr on it.
Fuel pump pushrod? Didn't think about that, I haven't had a mech pump in 25 years, It may need to be dropped.
Doug
The block has a code of V0109TJT which I believe relates to a truck engine either 69 or 79 , with the sump off this weekend I can confirm it has four bolt mains . Pistons look pretty flat and are +040
The heads have codes of GM18 / F10-71 1971 , 74cc chambers 1.72 intake and 1.5 exhaust , pretty standard I guess ?
Edlebrock Performer C3B inlet manifold and a Holly 600 cfm 4150
Any thoughts on a cam that would suit this mixture .
Cheers
Mike .
