I have this problem too with the original clock in my '64 - runs a bit too fast. The clock was running erratic. The rewind mechanism wouldn't 'fire', as it should. Poor contact between the dirty coil-fired points was the problem. These were cleaned and adjusted. The clock gear mechanism was also cleaned and lightly lubed. The clock runs like a champ, now! ..
A bit unorthodox but for adjustment purposes I wired in a small toggle switch and 3 amp fuse into the electrical plug that feeds the clock. The idea was to turn the clock off and let it 'catch up' to the correct time, so to speak. The switch also allows the clock to be turned off so it isn't constantly running when the car sits.
When the clock guts were exposed I didn't see anything obvious, such as an adjustment screw with a + and - , or something that would adjust the clock speed. Perhaps someone who knows these mechanical clocks can chime in with how this is done. I'd like to know, too!
From: Tank sticker? I ain't got no tank sticker! I don't need no tank sticker! I don't have to show any stinking tank sticker!
There is an internal regulation mechanism that adjusts the speed of the clock. I don't know how many seconds each turn back will produce.
Cheers
Yep, that's true, BUT I also don't know how many 12 hour increments you have to turn it back to slow it XX number of seconds. (or turn it forward to speed it up).
Mine runs well, when it's running. I keep my battery turned off. Chuck
...............is to do a Quartz movement conversion.
Did mine 15 years (!) ago; works perfectly and doesn't gain or lose time. Only difference is that the second hand now "sweeps" smoothly where the points movement did each second incrementally. For a driver it doesn't matter; for a show car to be judged I understand it to be a minor (1 point?) deduction. If you're going to have the clock out and the case apart anyway to try and do the adjustment on the points movement you're about 95% of the way towards doing the quartz conversion anyway - and you'll probably never need to mess with it again as long as you own the car - or live!
Big deduction. I think it's a 25 pointer in the Operations Section . Chuck
The internal adjustment doesn't work by turning it back nor forth....it should but it won't.....they had a idea but it didn't work.
You can try but I have many times and have never had one work...only way to adjust is to take it apart and manually adjust.
When the clock guts were exposed I didn't see anything obvious, such as an adjustment screw with a + and - , or something that would adjust the clock speed. Perhaps someone who knows these mechanical clocks can chime in with how this is done. I'd like to know, too![/QUOTE]
When you can see the movement there is a small brass half moon ....it slides ...thats the adjustment.
For one not set up best thing to do is to set a small power source up and adjust accordingly you can tell which is faster and slower once you dial in to the half moon.
Jason
I agree. the best way to dial it in is when the movents out, hook it to a power source and install the minute hand and run it for several hours. When you see it's gaining or losing move the half moon thingy and run it some more. Once you feel it's pretty close run it for 12 hours to see how far off it is. Looking down at the half moon thing from the top, pushing it a bit to the right should speed it up, to the left, slow it down. Good luck
