alternator output
it has a new(rebuilt) 65 amp alternator, and a new voltage regulator
the battery is a yellow top
is this the normal voltage?
thanks
It seems to me that your charging system needs to be checked.
One quick way is remove the plug from the regulator.
Bring the RPM up to approx. 1200 and jump the red wire to the blue wire on the connector for a moment. The voltage should rise above 15v. If it does not rise at all then I would suspect an alternator. If it does rise I would say either regulator or a wire problem.
so i guess i got a bad alternator; all the engine wiring was replaced
will an optima battery only command the amount of voltage it needs to charge?
the alternator it had on before was a newer style gm alternator but the only harness that was hooked up was the red wire only?
BTW
what alternators is everyone running? i see the kits to run a newer style gm and the harness adapter is made to fit your wiring? is this worth doing? the alternator i installed is a 63 amp, but now i need to get another one by the readings, its only about 2 months old
thanks
Jeff
today i just tested it and it was puting out 11.59 when at idle, no change with acceleration, but when i put on the headlights, it was at 11.2
i just assumed the regulator was good, i never checked it before i took off the incorrect alternator, i dont know how it was charging with just 1 red wire?
so i bought another voltage regulator
installed that same reading 11.59volts
checked my battery with out the car running, 11.59 volts
does an optima battery not need a full 12volts? very strange, the starter does not lag cranks right over!!!
Your wiring is the next place to check. Follow Buns alternator test method as he posted previously.
Plasticman
If nothing changes then I would suspect that there is something wrong with your new wiring harness. This wouldn't be the first time.
when i replaced my harness, i had to buy the alternator relocation harness, i found the black wire connector was unplugged
i reconnected and tried it, i still had the same amount of charge, 11.59
the battery is also at 11.59, so i hooked up a trickle charge to get it up to 12v and see what happens
But, what the heck, if you want to rule out the regulator as the problem, below is a test for that.
Unfortunately, most of the tests for the regulator involve specialty equipment, such as
ammeters that can handle the full output of the alternator. There is one simple test that you can do.
REGULATOR VOLTAGE TEST
1: Connect a voltmeter from the junction block on the horn relay to ground at regulator base.
2: Turn on high beam headlights and heater blower motor to high speed. Run engine at or above
1500 RPM (for a few minutes, if necessary) and read the voltage on meter.
Note: Voltage will not greatly exceed 12.5 volts until the battery develops a surface charge, a few
minutes generally, unless the battery is severely discharged, or is hot.
3: If the reading is less than 12.5 volts you can try adjusting the regulator voltage. Disconnect the 4
terminal plug from the regulator, remove the cover, reconnect the plug. You do this to insure you don't
short out the regulator. Repeat step 2 and turn the voltage adjusting screw to raise setting to 12.5 volts.
IMPORTANT: Wrap the shaft of the screwdriver with electrical tape as you do not want to short out the
regulator. Also, make final adjustment by increasing spring tension to assure contact between screw head
and spring support,
4: Shut off engine, remove plug from regulator, replace cover, reconnect plug. Cycle the regulator by unplugging
the connector from the alternator. Reinstall the connector and recheck voltage setting of regulator.
