Another 63 Vert Problem
Old Apr 21, 2007 | 09:30 PM
Timbrr's Avatar
Timbrr
Default Another 63 Vert Problem
This got interesting. This 63 is a 327 with a 4 speed. A couple of times today I could not get the car into reverse. Got gas tonite and it didn't want to go into any gear. Finally got it into gear got home and it would not go into reverse. A couple of times it felt like it would but then the gears started grinding. Finally got in reserve and in the garage.
Is there a trick to getting into reverse or do I have a tranny problem. I do know the engine has just been rebuildt and to me it idles a tad high. Anybody have a thought?
Old Apr 21, 2007 | 10:03 PM
Blk63Vette's Avatar
Blk63Vette
Hello
If mine doesnt go in reverse ..I let it roll lil bit...I am told its a seperate non syncro gear...
Old Apr 21, 2007 | 10:07 PM
Timbrr's Avatar
Timbrr
Default Another 63 Vert question
Do you try and shift into reverse while it's rolling or just let it roll stop and try again?
Old Apr 21, 2007 | 10:15 PM
Blk63Vette's Avatar
Blk63Vette
Hello
Let it roll lil bit STOP.. then try and shift it
66since71's Avatar
66since71
I think the owner's manual may even give you this tip: With the car stopped and the clutch depressed, put the car in first or second gear first, then into reverse. (Reverse is not "synchronized".)
Not going into forward gears sounds like a shifter alignment problem. If you can't find the instructions in the shop manual for doing the shifter alignment, let us know.. May also be that the clutch is not fully disengaging. This adjustment is in the manual too...
Old Apr 21, 2007 | 10:18 PM
mdz06vetter's Avatar
mdz06vetter
St. Jude Donor '05-'10-'11-'12-'13-'14-'15
correct on putting in a forward gear before trying to put in reverse - also, are you sure you are depressing the clutch completely!? if not, many times it is virtually impossible to get into gear
Old Apr 21, 2007 | 10:25 PM
nassau66427's Avatar
nassau66427
Active Streak: 90 Days
From: going faster miles an hour...with the radio on in browns mills new jersey
Here's the quote from the owner's manual {'66, don't know if the others have it too}
"Shifting into reverse is made easier if you start to shift into any other gear before going into Reverse."
Old Apr 21, 2007 | 10:37 PM
62Jeff's Avatar
62Jeff
Often my 65 won't go into reverse unless I start to release the clutch while trying to put it in reverse - then everything lines up and it falls right in place.
Old Apr 21, 2007 | 10:41 PM
w1ctc's Avatar
w1ctc
If the shifter is original and has not been rebuilt it could cause the
problems you have. Many of us have been there with hung up shifter rods and have joined the "greasy Hand Club" after getting under and pulling the rods back in position. It only happens with your good clothes on
To Another 63 Vert Problem
