Almost finished rebuilding my 350 motor but am unclear as to the correct position for the heat riser restrictor/s on the manifold gasket .
I have fitted later heads (79) to allow for use of unleaded fuel and am running an Edlebrock performer manifold .
Can you please advise as to which side if any the restrictor should be fitted , is it needed with the Edlebrock manifold ?
Also what is the reason for fitting these restrictors what do they do and what are the consequenses of getting it wrong ?
TIA
Mike .
are you referring to the plates that close off the crossover passages of the intake?
If so, many people close them off if they remove the heat riser valve from the passenger side exhaust manifold - between the manifold and the exhaust pipe.
The crossover passages allow exhaust from the passenger side cylinders to exit thru the intake and out the drivers side exhaust while the heat riser valve is closed when starting cold.
If you remove the hear riser valve and block off the crossover passages with certail intake manifold gaskets the downside is that it just takes a little bit longer for the car to come off the choke when cold.
FWIW, last year I removed the heat riser valve off my '65 and as per recommendations installed new intake gaskets that closed off the crossover passages. It completely changed the sound of the exhaust thru the sidepipes. Since I only drive the car in the summer I don't see much issue with a prolonged warm-up before the choke kicks off so that's not an issue but the changed exhausr sound is and I don't like it. I just got new intake gaskets to change back to an open crossover.
TIA
Mike .
Depends on your carb/choke setup. If your choke runs off hot air from a tube in the exhaust manifold, it won't matter. If it runs off a remote thermostatic coil in the intake manifold with a rod to the choke lever, you need the crossover passage open in order to provide heat to the well the choke thermostat is mounted in.
Thanks for the replies , I am running a 4150/600 Holley with auto electric powered choke set up . So if I have this right I can probably manage without restricting either side , or should I restrict the drivers side to allow more heat to the passenger side which is the side of the choke . I am not too concerned about warm up times as like Barry I only run in decent warm weather ( when we get some in the UK ) .
My thought is to leave them both fully open , what do you think ??
MIke .
My intake manifold crossover passage is open and the heat riser valve (passenger side) is welded open as you can see from the exhaust trails; cold morning/startup last October.
Thanks to all for your thoughts , I have now fitted the manifold with no restrictors , all I need to do now is get the motor back in the car and get it fired up .
