St. Jude Donor '06-07-'08-'09-'10-'11-'12-'13-'14-'15-'16-'17-'18-'19-'20
Originally Posted by Red63SW
Thanks! I don't see it listed in any parts catalogs. Is it not available reproduction?
Chris
Been through the experience of finding all the moldings for a 63 coupe and, other than the rear window corners, haven't found any moldings being reproduced thus far. Some vendors (such as Paragon) may have used originals though and you may want to check with them.
You should be able to use the 64 up if you change the clips. The 63 has a longer flange and uses different clips.
The 63 coupe is different from the 64, the ridge is on the lower edge on one and the upper on the other. So I assume fronmt the comment above, same goes for the vert.
