64 speedometer cable
Old May 2, 2007 | 09:03 PM
piper's Avatar
piper
Default 64 speedometer cable
Need help with my 64 speedometer cable I need to replace the speedo gear in the transmission. I did it on my 67 .but the 64 is on the driverside and looks like you can not get it off unless you drop the tranny brace? has anyone taking it off and is there something I am not seeing Thanks in Advance
Old May 3, 2007 | 07:42 PM
piper's Avatar
piper
Ttt
Old May 3, 2007 | 11:02 PM
splidecision63's Avatar
splidecision63
I jst replace mine. I bought a new 54" cable and found it was to short, about 1/8 ". So, I called John and he told me that if I had a later Muncie than a 64 it would take a 70" cable. Well my 1964 corvette has a 1968 Muncie in it and it does take a 70" cable. All I did was run the cable over the transmission and hooked both end up. I did not run across any problems. Good Luck
Old May 4, 2007 | 01:55 PM
piper's Avatar
piper
Hi, if you have a 1968 Muncie than the cable hook up is on the pass side Mine is a 64 and it is on the driver side and very hard to get to I would like to know if anyone has taken it off without droping the tranny brace thanks
To 64 speedometer cable
