harmonic balancer
Old May 4, 2007 | 09:51 AM
rickm63's Avatar
rickm63
Default harmonic balancer
Is a stock 6"by 3/4 ok to use with a .485 lift cam?or should I go bigger.
The timing cover tap is made for a 6 inch.
Old May 4, 2007 | 02:04 PM
nvr-enuf's Avatar
nvr-enuf
Default Harmonic balancer size
From my understanding, the harmonic size does not have anything to do with the cam specs. The harmonic offset weight is meant to go hand in hand with the crank that is the motor to ensure the motor is balanced.
Old May 4, 2007 | 05:22 PM
Scott Marzahl's Avatar
Scott Marzahl
Your choice of damper has nothing to do with your camshaft selection. If you are currently set up for a 6 3/4" damper than by all means use another one.
Old May 5, 2007 | 12:20 PM
JohnZ's Avatar
JohnZ
Actually, it has nothing at all to do with engine balance (except on an externally-balanced 400SB, 454, or 383); it's a "harmonic damper", and attenuates crankshaft torsional vibration, not balance.
Old May 5, 2007 | 09:23 PM
Pop Chevy's Avatar
Pop Chevy
2021 C1 of the Year Finalist - Modified
No problem ! Let's em wind up quicker. I used to run the small damper on my 355's.
Pops
To harmonic balancer
