C-1 doortrim interchangeability
Old Oct 20, 2001 | 10:02 AM
59er's Avatar
59er
Default C-1 doortrim interchangeability
Hi guys,
I have got 62 doortrims in my 59 but believe the doors to be original.
Are there any differences with regards to winder, lock and latching positions.
Basicaly I want to replace the doortrims with 59 trims but need to confirm that they are 59 doors and not 62.
I don't believe that there are differences but would like this confirmed as the cost of 59 complete trims are real expensive and by the time I get them over here in Australia they're triple the price.
Thanks for any help.
Mark.
Old Oct 21, 2001 | 01:59 AM
Curtis's Avatar
Curtis
Default Re: C-1 doortrim interchangeability (59er)
If no one knows for sure I could measure my '60 panels for you. '59 and '60 are the same. Let me know if JohnZ or someone doesn't know for sure.
My e-mail is hcstock@home.com if you need to reach me fast.
Enjoy,
Curt
Old Oct 21, 2001 | 06:05 PM
plaidside's Avatar
plaidside
59-61 door trim is the same, only the stainless is different. The 62 door uses a smaller arm rest, therefore only two screws holding it to the door, the 59-61 arm rest uses three. I had this trouble with my 61, someone put a 62 door on mine, and ground the beading of on the outside and put the stainless on. I had a hell of a time with the two front armrest screw holes. The other thing with 61-62 doors, are that they are longer on the outside by 1". If you want to see it, go to photopoint.com, then type in jefish@redconnect.net.
Take note of the white 61 door, look at the distance between the two screw holes under the door handle. The 62 ones are much furture apart.
Old Oct 22, 2001 | 07:43 AM
59er's Avatar
59er
Thanks Guys,
I believe that the locations of the winder and door lock/release are the same which was my main concern.
Thanks for the replies.
Mark.
Old Oct 23, 2001 | 07:06 PM
burked3's Avatar
burked3
My '61 had a 2hole armrest door on the passenger side. The previous owner had brazed a screw together to at least put two screws in it. I'm not sure what year door it is, but to fit the new door panels on my '61 I had to replace the interior lock mechanism. The shaft was about 1/4 too short to put the **** on. Other than that and the armrest, I noticed no difference in the door panel layout from the drivers door (which I assume is an original '61 - I hope)
Hope the info helps.
Old Oct 24, 2001 | 11:25 PM
PhilG's Avatar
PhilG
Default Re: C-1 doortrim interchangeability (Curtis)
I am building a '59 but have '58 doors. all the research i find shows that the '58 year is the only odd ball year as far as where the door mechanisms are located. "58 parts , naturally, are the most expensive. The 61/62/ doors are different on the outside as they had no cove trim. On the inside they should be the same as the '59. :hat
Old Oct 25, 2001 | 02:26 PM
58Mike's Avatar
58Mike
Default Re: C-1 doortrim interchangeability (burked3)
PhilG-
Just so you'll know, Al Knoch will use '59 fabric on '58 door trims for a small extra charge, if you want. I did it for my interior because I like the color from '59-'60 better.
- Mike
To C-1 doortrim interchangeability
