Flywheel/Starter
Old May 13, 2007 | 06:08 AM
terrys61's Avatar
terrys61
Default Flywheel/Starter
Now what do I do??? Removed a 350 from my 61 and replaced with a 283. Engine is installed and installed a correct 283 starter. Problem that I now have is that I failed to determine what the flywheel size was when I removed it from my 350. The starter does not engage the flywheel. So it looks like I cannot use the correct starter and will have to get another. Any suggestions on this?
Old May 13, 2007 | 08:23 AM
Bowtyeguy's Avatar
Bowtyeguy
It seems you should use the 350 starter in it. You used the flywheel that came off the 350 engine? That would be my guess, its what I would try first.
Old May 13, 2007 | 02:12 PM
AZDoug's Avatar
AZDoug
C1 of Year Finalist (performance mods) 2019
2017 C1 of Year Finalist
What bell do you have? An original '61 bell or something else?
If you had a block mounted starter, and you now have the bell mounted starter,and you have a small flywheel, you will have to go back to a block mounted starter, if it will clear the bell housing.
DZAuto knows more about starter intechangability/fitment issues than me.
Search his name and flywheel and starter, you will get some good info
Doug
Old May 13, 2007 | 02:23 PM
JohnFromVentura's Avatar
JohnFromVentura
You need a 168 tooth flywheel (not 153 tooth).
Old May 13, 2007 | 03:46 PM
JohnZ's Avatar
JohnZ
If you have a C1 bellhousing, it takes a bellhousing-mounted starter, which requires a 14" (168-tooth) flywheel; no other combination will work. If you have a later C2 bellhousing, that takes a block-mounted starter; DZAuto can tell you what your options are for that based on how your block pad is drilled.
Old May 13, 2007 | 11:41 PM
DZAUTO's Avatar
DZAUTO
2026 Corvette of the Year Finalist - Modified
2025 c1 of the Year - Modified Winner
2024 C1 of the Year Finalist - Modified
2023 C1 of the Year Finalist - Modified
2015 C1 of the Year Finalist
Very good info above.
There are only TWO sizes of flywheels (or flexplates for auto trannys), 14in diameter (168 teeth) and 13in diameter (153 teeth). There are no other sizes, period.
Thus, you must have the appropriate starter to match the flywheel size that you have.
You mentioned that you installed a "correct" 283 starter and it will not engage your flywheel. Right up front, that tells me that your correct 283 starter is mounted to the bell housing, AND, it will ONLY work with a 168 teeth flywheel. If this is what I have correctly understood, all you need to do is locate a big, 168 teeth flywheel. Also, if the flywheel on your 350 was the smaller version (153 teeth), then that means that you also had a 10 1/2in clutch. Only the EARLY 168 teeth flywheels had a bolt pattern for a 10 1/2in flywheel. All the later 168 teeth flywheels had a bolt pattern for an 11in clutch (I personally prefer an 11in clutch over a 10 1/2in clutch). Sooooooooooooooo, if you can't locate a 168 teeth flywheel with the bolt pattern for a 10 1/2in clutch, then you will need to swap both the flywheel and clutch. Have I thoroughly confused you?
Old May 14, 2007 | 12:01 AM
LB66383's Avatar
LB66383
Hays makes a 168 tooth neutral balance flywheel for the 350 that is drilled to accept either a 10-1/2 or 11 inch clutch.
Old May 15, 2007 | 06:13 AM
terrys61's Avatar
terrys61
I hace a 3779553 bell housing(believe to be correct). I have the engine already installed(everything hooked -up) the last thing i did was to install the starter-mounted to the bellhousing.Thats when i noticed the problem. I did notice bolt holes on the bottom of the block which appear to be for a block mounted starter? Do i just need a different type of starter. Hate to pull the engine again. Or can i get to flywheel from the rear by removing trans and bellhousing? Thanks
Old May 15, 2007 | 07:58 AM
terrys61's Avatar
terrys61
Would this be the correct part Hays #H2910010 that I would need that would accept the 10-1/2 or 11 inch clutch? Thanks
Old May 15, 2007 | 12:01 PM
AZDoug's Avatar
AZDoug
You can replace the flywheel from under the car by removing the trans and bellhousing.
Make sure you support the rear of the engine.
if the car is way up off the ground, i used a long chain wrapped and both side of the frame and bolted togther, and a scissors jack between the chain and oil pan to adjust engine position.
You may, i repeat MAY, be able to use a small gear drive starter off a late model Corvette with that bellhousing. It mounts to the block. if you can go this route please note that i had to put a flat washer on each starter bolt as shims between the gear drive starter and block as the early blocks are machined a little differnt and the starter was being canted at an angle due an irregularity in the mounting pad.
Doug
To Flywheel/Starter
