461 head question
Old May 13, 2007 | 10:55 AM
Kensmith's Avatar
Kensmith
Default 461 head question
I have a set of 461 heads for a 65 327. One head has a casting GM 9, the other GM 7. One dated 6-12-65 and the other 6-17-65. Any idea why the different GM number?
Old May 13, 2007 | 11:51 AM
Kensmith's Avatar
Kensmith
Originally Posted by Seaside63
I understand that represents the mold number. The two came from different molds.
Any idea how many different molds at the plant? Reason for numbering the different molds? Maybe quality control?
Old May 13, 2007 | 12:00 PM
knight37128's Avatar
knight37128
Thousands, two plants, big blocks, small blocks, six cylinders, four cylinders, plus all the other cast stuff.
If a part came to inspection, (after it cooled down enough to touch) and it did not pass they could track it down it fix it (just a guess).
Old May 13, 2007 | 12:06 PM
DZAUTO's Avatar
DZAUTO
2026 Corvette of the Year Finalist - Modified
2025 c1 of the Year - Modified Winner
2024 C1 of the Year Finalist - Modified
2023 C1 of the Year Finalist - Modified
2015 C1 of the Year Finalist
If you go look at MANY GM castings, you will most likely see the GMXX mold number on them (somewhere). Imagine if you will, if there was only ONE mold for a block, one mold for a head, one mold for a rearend casting, etc, etc, etc. It would take FOREVER to turn out block, head, intake manifolds, etc. Sooooooooooooooooooooooo, there are multiple molds for the raw castings.
Next, why does each mold have a number, ie GM1, GM2, GM14, etc? Well, you touched on it. When a number is put on a mold, it provides a level of quality control by allowing inspectors to go straight to the mold which a cast part came out of, if a problem is discovered with that casting. Then the mold can either be corrected or discarded. Molds for cast iron castings are sand molds, so if an imperfection is discovered, the mold can ususlly be "fixed".
Such a thing may exist, but I have never seen a set of dies for die casting iron. Metals such as alum is usually where die casting is done. A good example between a die and sand cast alum part would be a carb housing is die cast and an intake manifold is sand cast.
Hope this helps.
Old May 13, 2007 | 12:57 PM
Kensmith's Avatar
Kensmith
OK, now when they put a motor together, did they try and use heads from the same numbered mold? Would my #7 and #9 not be correct for my motor?
Old May 13, 2007 | 04:20 PM
JohnZ's Avatar
JohnZ
There was no attempt whatsoever to try and match either dates or pattern numbers; the pattern number was for internal traceability - if there was a problem with a casting, they could go straight back to the pattern to see if that was the problem, and the dates allowed them to quarantine castings from that pattern until the problem was defined.
The patterns were usually made from iron or stainless steel, and there were up to 30 identical patterns for a high-volume casting; when the green sand was packed around the pattern, the sand became the 2-piece "mold" after the pattern was removed, and the sand "mold" was destroyed when the mold and casting hit the "shake-out" table after the casting cooled.
See my technical article in the February '07 issue of "Corvette Enthusiast" magazine for a complete photo-illustrated description of the Chevrolet iron foundry processes.
To 461 head question
