1960 Acceleration Problem
which is another story) but what my main concern at this time has to do with the acceleration. The car idles fine @ 900-1000 rpms but when you go to accelerate it seems to chug and bog down until you get to about 2500 rpms and then it accelerates very smoothly from there. I can't seem to figure out what the problem is. The car has the original 283/245 2x4 engine with 3 speed transmission. The engine was rebuilt about 3 years ago and the carbs were rebuilt about the same time. The car ran fine prior to this winter's projects. I know someone here will be able to figure this out but I sure can't. Any help you can give will be greatly appreciated.Scott
If you are getting bog, first thing to look for is not enough fuel. Not an expert on your particular carbs, but the problems have the same cause.
Doug
