Phosphoric Acid Rustproofing PROBLEM!!
Old May 14, 2007 | 08:59 PM
mikem350's Avatar
mikem350
Default Phosphoric Acid Rustproofing PROBLEM!!
Been etching sections of my frame with phosphoric acid for a while. Let dry overnite. The last time (after sandblasting) every time I wash off the acid a thin coat of rust forms in 5-10 minutes. Tried 3-4 times, same problem
Previous rust removal was mostly wire brush and grinding with great results.
Once a good phosphate coating is down do you still need to prime???
TIA Mike
Old May 14, 2007 | 09:26 PM
GCD1962's Avatar
GCD1962
Wipe it down with a strong vinegar solution, or look in Eastwoods catalog, they have a powder that mixes with water that prevents the rust from reforming for a short time before painting
Old May 14, 2007 | 10:13 PM
project63's Avatar
project63
Why are you using acid if you have a sandblaster? There is no need to etch metal following sandblasting.
If you feel you must, then rinse the acid with a soda water mixture. I mix a 1 pound box of baking soda in 5 gallons of water. This neutrualizes the acid and slows down the rust formation. This is especailly important for areas inside the boxed frame. Otherwise rust will continue to prosper.
You still need to dust a coat of primer over bare metal as soon as it's dry and frankly I wouldn't be using acid at all on a frame unless It was done professionally by dipping the complete frame into a netrualizer following acid etch.
tc
Old May 15, 2007 | 12:27 PM
Scott Marzahl's Avatar
Scott Marzahl
That "rust" is the phosphoric acid wash doing it's job, what should be happening is the forming of a light coat of zinc phosphate that protects the metal from moisture, it should look kind of brownish gold, now just primer it after it dries.
Old May 15, 2007 | 08:32 PM
gonefishn's Avatar
gonefishn
St. Jude Donor '09
I also agree with Scott. First wash off the part to remove the converted rust then reapply the phoshoric acid (very light clean rag). Once dry you can tack the part and paint without the second rewash.
Remember also to dilute the phoshoric acid after use and use it as a plant fertilizer. There is a strong concentration of iron oxide and phosphates. Best not to pour down the drain since being a fertilizer (phoshates) it's not the best for lakes and rivers (algea).
John
Old May 16, 2007 | 09:31 AM
John McGraw's Avatar
John McGraw
Mike,
You are confusing phosphoric acid and a phosphate treatment. The phosphoric acid is simply for removing rust, while the phosphate treatment will prevent rust on bare metal for an extended peroid of time. I use a phosphate rinse on all my blasted parts if I am not painting them imediately, and all my blasted parts that are going to the powdercoater get the rinse since I never know how long they are going to let the parts sit around before working on them. I have phosphate treated frames, and they are still rust-free 2 months later! I buy a commercial grade of phoshate, but the stuff that Eastwood sells is the same thing, you just have to mix the powder with water. It is pretty simple to do, just rinse the parts in the phosphate solution and let them air dry.
Regards, John McGraw
To Phosphoric Acid Rustproofing PROBLEM!!
