engine help
Old May 16, 2007 | 06:47 PM
draakarmaul's Avatar
draakarmaul
Default engine help
Ive got a 61 w/ a 327 and 4 spd. Just rebuilt the motor (nonstock cam) and am having a few problems.
1. what should I set the initial timing to?
2. what about "total" timing?
3. Ive got solid lifters- I keep checking them and the lash is TIGHTER than when I originally set it. any ideas?
Old May 16, 2007 | 07:33 PM
AZDoug's Avatar
AZDoug
C1 of Year Finalist (performance mods) 2019
2017 C1 of Year Finalist
i would suggest 10 degree intial advance, 32-24 total adavnce, depending on compression ratio, maybe 36 total if you have 9;1 pistons.
Do you do a valve job? Valves seating in woudl tighten up the lash.
Doug
