Help
Old May 23, 2007 | 09:04 PM
DFA's Avatar
DFA
Default Help
I recently put new carpet in my '66 convert. I'm trying to install the center cushsion between the seats but I can't find the hole the post on the back of the cushsion sticks into
What am I missing ????? Is there an easy way to locate it ? I didn't think it would be such a problem and of course I have the carpet now glued over it.
Any ideas or measurements ???
Old May 23, 2007 | 09:54 PM
66BlkBB's Avatar
66BlkBB
St. Jude Donor '13-'14-'15-'16-'17
I would just use an awl or an ice pick and start probing. You know approximately where it should be located by simply holding the center arm rest up to it. I take it that it was there when you tore the car apart. It couldn't have disappeared unless the metal bracket broke off. You should have seen that when you put the glue down, if that happened. Shouldn't be that hard to find. You probably filled it with glue and carpeting when you glued it down. Good luck.
Steve
Old May 24, 2007 | 09:28 PM
Willcox Corvette's Avatar
0Willcox Corvette
Former Vendor
St. Jude Donor '08-'09-'10-'11-'12-'13-'14-'15
Take out the jack board cover and locate the hole. Then run an awl through the hole from inside the rear jack compartment.
Old May 24, 2007 | 09:35 PM
DFA's Avatar
DFA
I'll give that a try. I didn't think the hole was below the cover. I'll check it out tomorrow.
Thanks,
DFA
Old May 25, 2007 | 12:18 PM
DFA's Avatar
DFA
I found it
Thanks,
DFA
To Help
